Old 08-12-2019, 01:04 PM
Tanksta's Avatar
Tanksta Tanksta is offline
Default Recommendation on a FRAME BOX KIT
I've got a 67 GTO/Lemans frame that I want to box. Does anyone know of a kit like the Hellwig 11100 that would work on this frame? Going under my 67 LeMans vert.
ID:	517536   Click image for larger version
1967 Lemans Convertible_____Tanksta's facebook page______
Old 08-12-2019, 01:56 PM
242177P's Avatar
242177P 242177P is offline
11100 is 68-72, 11102 is 64-67
https://www.summitracing.com/int/par...1102/overview/
Old 08-12-2019, 03:10 PM
Tanksta's Avatar
Originally Posted by 242177P View Post
Thank you, Sir!
Old 08-12-2019, 08:58 PM
gtospieg gtospieg is online now
That frame appears to have some non-factory boxing done to it already...is that the case or am I imagining it?
Old 08-12-2019, 09:16 PM
400 4spd.'s Avatar
Is that the frame that was under the convertible?
Old 08-12-2019, 09:19 PM
marxjunk marxjunk is offline
the helwig, like linked above is the way to go..it picks up an extra mount and is almost invisible..ive done 3...easy to do..and can pass off as a factory convert style look..
yes..yours has been plated/boxed..
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 08-12-2019, 10:05 PM
67gtospud's Avatar
67gtospud 67gtospud is offline
That fame is already boxed. If you really wanted you could box it behind the rear wheel arches however it really isn’t necessary.
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears
Old 08-12-2019, 11:42 PM
Tanksta's Avatar
No, the original frame is still under the car. I actually have two frames. One is a 67 Elco that has 4 link set up, powder coated ready to go.....but it's set up for a 9" Ford rear.
I just purchased this 67 frame that has been partially boxed. It's only done on one side and they are just tack welded.
That' why I am thinking of the Hellwig box kit. Looks like stock.
I can also use the Elco frame and the rear of the 67 frame. So, I'm looking at all my options.
My body guy is really wanting the 4 link setup.
ID:	517613   Click image for larger version
ID:	517614   Click image for larger version
ID:	517615   Click image for larger version
Old 08-13-2019, 01:48 AM
KGTO's Avatar
KGTO KGTO is offline
I just did the hellwig kit and turned out great.
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @159 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
Old 08-13-2019, 01:50 AM
KGTO's Avatar
Another shot
1964 421 GP-Sold
Old 08-13-2019, 05:57 AM
Geoff Geoff is offline
Also interested in the box kit. Can it be installed with the body on the frame?
Old 08-13-2019, 09:46 AM
KGTO's Avatar
At the minimum you need to raise the body and it would be challenging..best is to remove the body
1964 421 GP-Sold
Old 08-13-2019, 11:16 AM
Tanksta's Avatar
Originally Posted by KGTO View Post
Another shot
That looks really nice!
Old 08-13-2019, 11:20 AM
KGTO's Avatar
Thanks!
1964 421 GP-Sold
Old 08-13-2019, 05:43 PM
I had seen some pictures it is a little bit of a pain around the trans mount area. Thinking of that on my 65 also.
Old 08-14-2019, 02:23 AM
Douglas Willinger's Avatar
Douglas Willinger Douglas Willinger is offline
Default 4 door Frame Box Kit
Which kit for 4 door sedans, hardtops and wagons?
The same year range 2 door frame box kits, or something else.
1970 Lucerne Blue Firebird Trans Am, deluxe blue interior. Original Ram Air III, M-21, 3.73. Being built as a 4" stroke "434" with SR 614 Ram Air IV heads
1972+ Lucerne Blue 4-door hardtop "what if" T-41 Le Mans Sport GT/Grand Am concepts. Equipped with future 3" journal "455 HO"/"what if" prototype "SD 455".
What if GM had continued production of the 1970-72 GM A body somewhere in the southern hemisphere?
Old 08-14-2019, 07:50 AM
Man, that looks better than factory. What’s an estimate on how long that would take to weld up, etc., not including the paint/powder coat?
Old 08-14-2019, 11:41 AM
KGTO's Avatar
I had probably 40+ hours in it all told (estimate). I'll try to take a pic of the underside, I blended the welds a lot more than needed but I wanted to do that. Lots of grinding and going slow on the welds. Having done it once I could go through it quicker now.
1964 421 GP-Sold
Old 08-15-2019, 12:23 AM
KGTO's Avatar
Not the best pics but you get the idea
ID:	517809   Click image for larger version
1964 421 GP-Sold
Old 09-07-2019, 12:53 PM
ZeGermanHam's Avatar
Question for those who have installed the Hellwig kit... To determine the correct position of the added body mount in this kit, is it necessary to temporarily put the body back on the frame? Or can you install the whole kit from start to finish with the body removed? Just trying to anticipate logistics...
Thanks.
1998 BMW 328is (track rat)
