Old 08-12-2019, 11:29 PM
dreamn69 dreamn69 is offline
Default Early inner handles on late model door?
Is it possible to mount the 70-74 inner door handles on a later door?
1979 W72 Fire Am
1976 Fire Am
Old 08-13-2019, 01:55 AM
HO Kenny's Avatar
HO Kenny HO Kenny is offline
Probably not without cutting and welding. However, you can use the early door panel with the latter model door as long as you use the late model and hanker surround trim piece.
Old 08-13-2019, 08:50 AM
That's what I did, used early braced doors, and have 79 door panels. Pretty sure all I did was open up the existing hole and use captured nuts to mount it.
I would have to take the door panels off to check to be sure, but that should be in like Oct, if you can wait that long. Might be able to get out there sooner, if you're thinking of doing something soon.
Old 08-13-2019, 08:52 AM
Oh wait, dyslexia kicked in, you want to use early handles in a late door? Not sure the inner structure will support that.
Old 08-13-2019, 11:28 AM
GREGGDOG GREGGDOG is offline
Inner structure needs to be welded/fabricated to fit early inner door handles.
I learned the hard way a long time ago when I unknowingly bought a 70' with later doors. Instead of modifying, I bought 70-74? doors.
Old 08-13-2019, 10:42 PM
That's what I was afraid of. unfortunately the doors were put on before I bought it. Thanks
1979 W72 Fire Am
1976 Fire Am
Old 08-14-2019, 10:54 AM
72projectbird's Avatar
I have one early handle and one late handle in my car. lol
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
