Old 08-02-2019, 01:54 AM
GILLIGAN GILLIGAN is offline
Default SPEED SHIFTING a M20
factory units
any luck at 6500 -7000 rpms ?
tq/hp around 550 flywheel
upon engagement
alum.fly/superlight clutch assy.
quick time bell/plate
ballistic grade right foot
thank yall
Old 08-02-2019, 03:08 AM
brut4s's Avatar
brut4s brut4s is offline
Check this out for a upgrade
http://www.wrightconnection.net/
Old 08-02-2019, 10:20 AM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
Stock up on cluster gear sets.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 08-02-2019, 12:50 PM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Yep. Many years ago I cleanly banged second gear in my '64. Next stop light, shifted normally into second gear, clunk clunk clunk... Snapped one tooth clean off of the cluster in my "Rock Crusher". I was making maybe 450HP max.
Old 08-02-2019, 02:05 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
What does the car weigh? What rear tires? Power shifting? Adjustable clutch?
Won’t be long for this life if stock, just not made for the type of abuse you can dish. Hardened input shaft, better gears, bushed case, etc would help a little. An adjustable clutch will help it live at the launch but the 2nd to 3rd shift will be killer.
Never had luck making them live, went to Autogear and that was better. Have a GForce now and that is a beast.
Good luck
Old 08-02-2019, 04:14 PM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
There is nothing you can do to make an M20 live with 550 HP.
Old 08-02-2019, 04:37 PM
GTOLiam's Avatar
GTOLiam GTOLiam is offline
Contact Paul Cangialosi at Medatronics Corporation - 561-743-5600
https://www.5speeds.com/newm22.html
He's extremely knowledgeable and a cool guy (Jeff Beck).
"Hammer to fit, paint to match"
Old 08-02-2019, 05:41 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
There is a reason why most of the stockers use Jericos and other trannies-any why in the 70s the GM SS and early ProStockers used Hemi and Ford Toploaders.
Skip Fix
Old 08-02-2019, 10:49 PM
Good luck
3800
any tire
keep right foot mashed and use clutch
only adj on clutch is left leg
thanks
Old 08-02-2019, 10:52 PM
interesting !
thank ya fer passin the knowledge
Old 08-02-2019, 10:53 PM
thank you bruce
my numbers are
conservative
Old 08-04-2019, 09:26 AM
Half-Inch Stud's Avatar
Routinely quick-shifted the 4-spd Saginaw with the OHC-6 at high RPM (6000-7500).
400 might survive with ST-10 from late 70s, M21-HD too
455 would be a crying matter.
Old 08-04-2019, 10:35 AM
alloy indian's Avatar
alloy indian alloy indian is offline
I think the horsepower to weight ratio might be the deciding factor. Back in the late 70s my brother when street racing would flat shift ( Throttle to the floor no clutch just slam the factory shifter at 6500 red line!) his 69 Firebird 350 HO car M20 stock Hurst shifter with 433 gears and G-60 tires all the time with not one breakage! The trans still lives to this day in this very car! The sound of that 350 singing at 6500 and only dropping about 500 RPM during a shift made me the 3 pedal junkie I am today!
Old 08-04-2019, 01:49 PM
FrankieT/A's Avatar
RPM is one thing...Torque is quite another...
Old 08-04-2019, 08:47 PM
455HOGT37's Avatar
455HOGT37 455HOGT37 is offline
I blew a M20 countrshaft at the top of 2nd on street tires. Stout 455 in a 68 Bird.
Old 08-13-2019, 01:32 AM
KGTO's Avatar
KGTO KGTO is offline
Do yourself a favor, save your Penny's and buy a Jericho. My 67 made 600RWHP, 700+ torque with a 150 shot. 3520 w/o driver. I did muncie, super case muncie and wound up going to a Jerico after foolishly wasting money trying to make the other stuff work. Twin disc Mcloed clutch, denny's nitrous ready drive shaft, 1350 yokes, 4.33 rear. Launched 5000-6000 rpm on a 2 step 28" slicks full exhaust/interior. Would run 10.20s to 10.50s. Keep a little slip off the line and I still hurt the tranny. Lots of fun though
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @159 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
