Old 08-20-2019, 04:47 PM
ejgoat ejgoat is offline
Default 64 gto rear axle bearings
I was told these are hard to find, have any of you guys run into this problem, if so where did you find them
Old 08-20-2019, 06:50 PM
Tom Vaught's Avatar
Boost Engineer
In a couple of oil cans in the basement (where I think I still have two sets of new 10 bolt Pontiac axle bearings).
Problem is, I have 30 feet of my son's house furniture in front of those two oil cans or I would be able to help you out.
He moved back to Michigan a month ago.
Tom V.
Old 08-20-2019, 08:09 PM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Don't see a problem with them, 1 day away from my Local Canadian parts place..skf or National RW507-CR,
comes with a sealed bearing and retainer.
64 Lemans hardtop
4spd, buckets
Old 08-20-2019, 09:07 PM
Cardo's Avatar
Cardo Cardo is offline
I bought Timkens on RockAuto.
"I know just enough to keep me here, but not enough to get me out"
Old 08-21-2019, 06:29 AM
Geoff Geoff is offline
I bought Timkens here also. Mine were made in China....
Old 08-21-2019, 12:14 PM
Cardo's Avatar
Mine were US made. Luck of the draw? I had heard Timken was starting to do that. I believe i bought my bearings about 2 years ago.
Old 08-21-2019, 03:11 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Anybody have Timkin USA part number on this 64-65 rear axle bearing they want to share?
I would like a pair for the shelf.
Thanks, Chris.
Old 08-21-2019, 08:42 PM
Cardo's Avatar
The number i ordered was RW507CR and that was in June of 2017.
Old 08-21-2019, 11:43 PM
Dick Boneske's Avatar
Go to Rockauto and order the bearings for a '64 GTO rear axle. Not a problem. They are $18.50 each.
NAPA also has them.
BONESTOCK GOATS
'99 Bonneville SE Sedan
