wanted first gen conversion v8 frame mounts for first gen
Looking for decent set of original V8 frame mounts and other parts that are required to go from OHC 6 to Pontiac 8 cylinder.
V8 AC brackets, Also interested in repro long branches, pypes exhaust, 8.5 rear with posi and either 308 0r 323 gears.
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
What year is the car and what transmission are you planning on running?
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int 1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int 1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int |
1969 and currently has 3 spd manual. i am swapping an m20 in. I am not super concerned with year to year accuracy, I just want it to look like it belongs there
I've got a two complete 69 firebird rearends. I have to check the gear ratios but I'm pretty sure they are both peg legs. Not a big deal to switch out the carriers as long as you reused the same ring and pinion and factory carrier shim pack.
If your talking the four plates that mount to the subframe I have a nice set
Sent from my iPhone using Tapatalk |
yes the brackets that come off the sub frame, that have a support bracket that comesup from th ebottom and bolts together. The motor mount attaching point. Any 67-9 326-400 car should have them
Copy that I have a complete set. Sent from my iPhone using Tapatalk |
A friend may have the Long Branch manifolds you are looking for. I'll inquire.
Tim john--- |
