Old 07-09-2020, 03:32 PM
notatempest's Avatar
notatempest notatempest is offline
Default What would you do? Repair or Replace hood?
Stuck on what to do. I've been stripping my 68 HO chemically for a couple months now panel by panel. I'm at the point where I need to make a decision on the hood. While the skin is in fairly good shape with a little rust on the front edge, the hood frame is pin holed. It's the original hood on a numbers matching car so I'd love to keep the hood. I'm doing most of the dirty work myself but separating the hood frame from the skin to repair is just something I'm hesitant on and I'm sure the labor to do it is expensive. Welding in patches with the skin on surely would warp the skin. I've heard the parts group hood is a decent replacement. What would you do? Repair or replace? Thanks!
ID:	544629   Click image for larger version
ID:	544631   Click image for larger version
ID:	544632   Click image for larger version
ID:	544633   Click image for larger version
1968 GTO 400HO 4spd Chrome Bumper Windward Blue
Old 07-09-2020, 04:16 PM
Not sure where you are located, but in my locale, & if the '68 is a higher end build, I'd source a nice clean '68 LeMans or Tempest hood & drill out the spot welds & after metal working the '68's hood skin, would reattach to the correct replacement inner bracing. '69 & '70 hoods have different inner bracing than the '68 hoods. The Goodmark (maybe its Dynacorn) hood that's been out 20 years is based on a '70 hood. Am about to source a repro for a '70 GTO that have in final metal work phase. Fully expect to have to build the ironing board area up some with a little filler on the repro hood that's always been an issue with them.
Old 07-09-2020, 05:15 PM
1_Wild_Cat's Avatar
I know a guy with the metal skills to fix it...if you happen to be in Boise?...
Old 07-09-2020, 05:32 PM
Not sure how skilled you are with a welder, but if it was me, I'd be cutting and slowly welding. At least you know how well that hood fits now!
Old 07-09-2020, 08:31 PM
PurelyGTO68 PurelyGTO68 is offline
Replace. The replacement hood from Ames is an exact copy of the 68 hood in every detail. As good as an NOS piece. I have had them both side by side.....its by far the best reproduction piece I have ever seen for the 68 GTO
Old 07-10-2020, 12:03 AM
MUSLCAH MUSLCAH is offline
Time to say good bye....before the latch area let’s go at 70 mph....
Old 07-10-2020, 12:15 AM
ignaro's Avatar
ignaro ignaro is offline
Cut it and put in enormous hood vents and a fake supercharger. Make it your "fun" hood. There are plenty of super-resto's out there.
Old 07-10-2020, 09:14 AM
dataway's Avatar
dataway dataway is offline
Speaking of hoods .... mine has surface rust on the underside ... bracing is nice, top is nice ... is it worth it to separate the bracing to get to the surface rust for removal? The level of rust is somewhere between "just use some rust converter", and "needs to be sanded down". Got to be a real pain to sand it between the bracing. I have all the necessary tools.
Old 07-10-2020, 04:27 PM
Obviously, this is certainly an easier fix. This is the one side of my brain in let's keep the project moving along because I have many other issues to grapple with metal wise. The other side is let's keep as much of the original metal as possible. Any photos of the ames hood? Thanks for chiming in, appreciate it.
Old 07-10-2020, 04:28 PM
Man, I wish...good metal guys are hard to find. East Coast
Old 07-10-2020, 04:35 PM
I've been looking and they're tough to find in the southeast. Any that I've come across need work as well or I have to drive to Minnesota or Wisconsin. I have that plan to separate the hood mapped out in my head and it hurts...lol. Know of any how to's on giggle?
Old 07-10-2020, 04:46 PM
That is probably another issue that I have if I decide to repair as is since the pin holes developed from the inside of the hood frame. I've thought about using internal frame rust converter to get to those areas. I've used it before and seems to work well. With the rust converter products on the market, I may give that a shot if I was in your shoes. I don't know for sure but it looks like a pain in the ass to separate the hood from frame.
Old 07-10-2020, 05:20 PM
Couple of recent photos. The Ames hood is an excellent piece.
ID:	544702   Click image for larger version
Old 07-10-2020, 09:59 PM
1965gp 1965gp is offline
I would go with the Ames hood and hang the original on the wall.
Old 07-10-2020, 10:28 PM
In my 44 years in the Autobody field...I have removed 1/4 panels from a used carcass....same with roofs.... but I have NEVAH even thought of removing a hood from its structure.....what a waste of time.....it’s a Pontiac...not a 1935 Bugatti ( sp )...
Old 07-10-2020, 10:56 PM
That's kind of surprising. You are finding better sheetmetal in MN and WI than in the southeast?
Old 07-10-2020, 11:59 PM
Notatempest......where you located ?
Old 07-11-2020, 12:13 AM
South Carolina near Hilton Head. I like your point of view, I’m one of those crazy’s that has to view all options over and over. I think I’ll get the Ames and keep the original. Maybe the next guy will fix it...lol
Old 07-11-2020, 12:31 AM
Is your car from that area....near the coast ?
Old 07-11-2020, 02:41 PM
No, car is from Cincinnati, OH.
