#41
Old 11-08-2019, 04:41 PM
Dragncar Dragncar is offline
Len Williams Engines has a good reputation for turn-key 455's at a reasonable cost. I have not used his services, but others here have. I personally would keep the 389, and would keep it smooth and stock-ish. The car is a full size luxury car, not a racer. It should have nice manners. I have run 389's, 400's, and 428's.....I like 389's because it just 'sounds' right, and is a proprietary Pontiac engines size, like 421. Good luck whatever you choose. A big, bread-and-butter 455 would be really nice in your car as well, and do it with less fuss than a smaller engine.
There is another 389, I looked it up in my dad Motors manuals where I was a kid. Don't remember the brand but I think it was a "off" brand like AMC or something.
Now 421 is, I have it as my race car number at our track.
  #42
Old 11-08-2019, 05:30 PM
carbking's Avatar
carbking carbking is offline
Originally Posted by hurryinhoosier62 View Post
On the street, you’ll be much happier with reproduction long branch cast iron manifolds from RARE. You’ll give up a little top end power but you’ll lose all the headaches of headers. It’s amazing how efficient Pontiac designed those manifold to be, and they are comparably priced to quality headers($569 a set).
Plus, you will be able to converse with the lady sitting in the front seat beside you!
Jon.
  #43
Old 11-08-2019, 07:41 PM
SRR's Avatar
SRR SRR is offline
Default This:
Go with the 455 for the best street engine if torque is what you’re after.
A bone stock 455 will make you smile, and will be less expensive than a hotrodded 389.
Both engines are great and have their place, but on the street cubic inches gets the job done without the need for ported heads and big cams.
Another thing to be aware of is 1966 389 blocks are not known for their strength and are also known for having very thin cylinder walls, I would avoid building a hot engine using that block.
A big Bonne needs a big engine, you won’t be sorry going with a mild 455. In later years (1969 for example) the 428 became the standard Bonneville power plant while all the other big Pontiacs came with the 400.
Big cars like 455 engines...makes them act like "A" bodies.
― Calvin Coolidge
Cold Case Radiators
Cold Case Radiators is a Max Performance company that produces high end aluminum performance radiators at a price point that won't break the bank. Polished and stamped tanks. 2 rows of 1" tubes. Lifetime Warranty.
GTOG8TA.com
GTOG8TA.com is a Max Performance company that manufacturers parts for the 04-06 GTO, 08-09 G8, and 93-02 Firebird/Trans Am platforms.
