Old 10-18-2019, 08:33 PM
68hotbird 68hotbird is offline
Default 68 firebird hei fit
Will a factory pontiac hei clear the firewall on a 68 firebird? Thanks
Old 10-18-2019, 09:15 PM
RocktimusPryme's Avatar
Yeah, I have one on my 67. The bigger problem is that it leaves very little room for error on the fit between the vacuum canister and the heater hose.
Old 10-19-2019, 06:38 AM
chrisp chrisp is offline
Yes , & be sure to remove resistor wire or run new wire to power the HEI
Old 10-19-2019, 09:31 PM
amcmike's Avatar
amcmike amcmike is offline
Biggest thing is getting the canister clocked properly, but it should fit. If the cap is hitting your firewall, check to make sure the subframe alignment isn't shifted back or cocked.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
Old 10-23-2019, 05:19 PM
gloryrestoparts's Avatar
gloryrestoparts gloryrestoparts is offline
I removed HEI from my 68 firebird. It was veeeeery close to the firewall, but it fit.
http://gloryrestoparts.20megsfree.com/
1970.5 Pontiac Tempest GT-37
400ci 4bbl 4sp 3.90:1
12.73 @ 112.42 2011 Pure Stock Drags
12.71 @ 110.58 2013 Martin FAST/FS race
12.70 @ 111.74 2014 Pure Stock Drags
12.60 @ 111.66 2015 Martin FAST/FS race
1968 Pontiac Firebird 400
TH400/3.08 open
export car - factory heater delete
14.48 @ 95.86 w/ 2.14 60' 2018 Pure Stock Drags
14.47 @ 95.02 w/ 2.16 60' 2019 Martin FAST/FS race
Old 10-23-2019, 06:55 PM
JLMounce JLMounce is offline
Yup have a large cap HEI on my 69 as well. As already stated, you'll have issues more with the vacuum canister than with the body itself.
-Jason
1969 Pontiac Firebird
Old 10-24-2019, 10:14 AM
MescaBug's Avatar
MescaBug MescaBug is offline
I have one on my 69 Bird. No problem. More room if you clock it with the vacuum can on the driver side instead.
Old 10-24-2019, 01:41 PM
I have to change the gasket on mine, Ill give it a look when I replace it.
