Old 05-09-2024, 12:50 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Default Home brew align bore... sort of...
Working on re-hashing my four cylinder hemi Pontiac as a two-cylinder, after severe detonation destroyed cylinder #2. Main web #2 of the aluminum block got beat up and needed cracks TIG welded, so #2 main bore ended up out-of-round. #1 & #3 bores are okay, so I employed my pseudo-align-bore contraption to make #2 round again at .030" over, so I'll use .015" brass shim stock behind the bearing insert (the #2 main cap survived without distortion).
Old 05-09-2024, 05:33 AM
steve25 steve25 is offline
Jack I think the plasticity of Brass will not stand up to the loading .
Maybe if there big enough so they can be cut down how about two .015" feeler gauges?
Old 05-09-2024, 08:46 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Looks good Jack. Where there's a will, there's a way.
Go fast, see Elvis!
Old 05-10-2024, 09:53 PM
Jack, this should work. What is the diameter of the cutter bar? The only foreseeable problem I can think of is chatter and possibly “swag” in the cutter bar.
Dr. Thomas Sowell
The Following User Says Thank You to hurryinhoosier62 For This Useful Post:
Old 05-10-2024, 10:36 PM
The mandrel is 3/4" diameter chrome moly and does not flex. It's a precise fit in the carrier blocks- would bind if not well lubed. With such a short tool bit, no chatter cutting cast aluminum up to .004" deep- I usually only cut about .001" deep, rotating the feed screw very slowly by hand.
The Following 3 Users Say Thank You to Jack Gifford For This Useful Post:
Old 05-13-2024, 12:56 PM
Thanks, Jack. I’m used to using a Berco BC-5 align boring machine with three different cutting bars and tool holders. Even with short bits ( carbide) and reduced feed speed (.5 inch per 100 rpm) we still had chattering problems using the 55mm bar ( roughly 1.5 inches).
Dr. Thomas Sowell
Old 05-13-2024, 02:06 PM
Stan Weiss's Avatar
55mm is just a little more than 2.165"
Stan
Pontiac Pump Gas List
