E85 Plug Gap?
Hey Guys - I have a 455 Pontiac with E heads and 12.5 - 13 to 1 and E85. I have MSD 6AL, Billet Dist, Blaser 2 coil and Firecore wires with NGK's #7 gapped .028 to .030 - Ignition locked with rotor phasing adjusted.
What is a good GAP for this Plug Set up? Thanks, Again, Craig |
I run both my e85 car's with out of the box gaps. Pretty sure 030 is the norm
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
I would change the heat to a #8 and gap at .035
My Half AN Injun..... |
charlie, what are you at for compression and whose carb? Are you turbo?
both my corn cars have Sullens Carbs on them
Not high , 11.4 to 1 . Cranking psi is 185. One is N/A and the other one is turbo.
I have a 1050 on the 11.4 to 1 car .Its a Holley tuned by me..
have you tried both heat range plugs?
Ive tried 8-9-10 in my N/A car , and 7-8-9-10 in my turbo car..
Thanks guys - the #7 now at .032 out of the box and switch to #8 during the warm weather.
Thanks Again, Craig |
Charlie, are you burning E-85?
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
How big of a factor does ignition spark intensity play?
I’m about to change to a NGK 5671-7 or NGK 5671-8 from a NGK 5671-10 and I’m looking for a gap recommendation. A heat range recommendation would be nice as well. I’m thinking the 8’s are going to be the recommendation but I figured I’d ask. 13.8-1 484 with highports and Holley EFI. I’m running Holley smart coils with 5.0 milliseconds dwell time
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
Yes i was then and i still run E85 now
Switched out the -10’s for -8’s today.
These are what came out. They were tapped at .022”
