Old 02-26-2024, 01:28 AM
Transamric's Avatar
I assume you removed the SoffSeal because it wasn't?
  #42
Old 02-26-2024, 06:48 AM
kencar62's Avatar
kencar62 kencar62 is offline
It was so tight my trunk wouldn't open. Being a solid profile vs. the Metro profile with air spaces, it wasn't compressing enough.
  #43
Old 03-04-2024, 05:10 PM
Transamric's Avatar
Time for an update/progress note. Decided to refinish the trunk gutter area due to many paint chips around the inner edge. Got a good paint match considering the rest is factory sprayed orig paint. Plus that gives me more time to mull over which weatherstrip I'm going to settle on. I make up my mind and then change it again. Now have a GM NOS strip coming that is not quite as tall as the later service replacement part I currently have.
Good input from all of you,...thanks!
Took these pics in a hurry just to show progress is being made. (Hard to take good pics of white & black with flash under fluorescent lights!)
Now on to the cleaning & restoring the taillights & installing the light harness (which is amazingly perfect).
Name:	'71 trunk prep #1.jpg
ID:	629835   Click image for larger version
Name:	'71 trunk prep #4.jpg
