Old 05-19-2024, 09:36 PM
MidnightAuto's Avatar
MidnightAuto MidnightAuto is offline
Default Buzzing from instrument cluster
Well, I am enjoying my winter projects results - car is running like a scaled ape and the new exhaust sounds incredible. I’ll put up a comparison on another thread to hear difference.
My question is this- I’ve all of the sudden gotten a buzzing coming from the instrument cluster. It loosely follows rpm and is quietest at idle, but still discernible. I’ve recently rewired msd box and the tach adapter, so not sure if something there. How would you trouble shoot this? thanks for any thoughts
Old 05-19-2024, 10:14 PM
Schurkey Schurkey is offline
Pop the speedo cable out of the speedo, see if the noise goes away or at least changes.
Old 05-19-2024, 11:16 PM
Bill Hanlon's Avatar
Mufflers are too quiet.
The Following User Says Thank You to Bill Hanlon For This Useful Post:
Old 05-20-2024, 06:03 AM
Kenth's Avatar
Kenth Kenth is offline
Sometimes the voltage regulator will buzz (just before it dies).
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 05-20-2024, 08:34 AM
steve25 steve25 is offline
Heat cycles over the decades have broke down the material holding the windings in place in the inductor in the old style regulator as stated in the above post.
Old 05-20-2024, 09:59 AM
GoGoat GoGoat is offline
You said you recently installed a MSD and tach adapter. Disconnect tach wire.
Process of elimination. Good luck. Let us know.
Old 05-20-2024, 04:35 PM
Ok thanks guys will report back
Old 05-22-2024, 12:20 AM
bhill86's Avatar
bhill86 bhill86 is offline
What year and model?
1977 Trans Am 400/4speed (swap)
Brian
