#41
Are you interested in having any made? Pretty sure someone on this forum or the OHC-6 one is running one of mine.
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
#42
Out of curiosity, are the flange clamps (? that the bolts go through) a standard size? Source? I need two or four of them for my "custom" exhaust.
__________________________________________ "How I learned to stop worrying and love the OHC Pontiac L6" The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!) 1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!) |
#43
there are 2 different styles of flanges
which one are you talking about?
#44
What will bolt to a '66 Sprint manifold. The clamps on the Y-pipe.
#45
2 different styles
flat ones(66) raised ones(67-9) both will fit a 66 manifold flange is for 1-7/8 66 used short bolts because the flange was flat
#46
Are they available for purchase individually?
#47
good question
Im running low on them so will check. which style are you talking about?
#48
Ones that will bolt to a '67 manifold?
Here is a picture of the one that came on my dual exhaust manifold, so one like it??
#49
If you have any old exhaust shop in the area check with them you would be surprised what you might find.
Also check with Inline they offer Clamps & Flanges and might have a suitable part. http://inlinetube.com/Exhaust/Exhaust.htm
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
#50
No true exhaust shops in town (next town is 185 miles out and I don't know if they have one either). The local mechanic shop has an exhaust tube bender and flarer and I had them make me a pair of straight pipes with flares at the end, but they did not have clamps.
I will check out the link, thanks!
#51
I'm sure you've seen it by now, but my winged in collector. The collector pipe is 2.5" because that is what I have laying around as left overs from other exhaust systems and no where in town sells exhaust pipe reducers.
#52
Not bad at all. Have you checked for fitment inside the car?
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213) 99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale http://sohcsix.yuku.com/forums/1/OHC-lounge Wanted: 1969 OHC "H" Camshaft |
#53
No, I'm banking on it not fitting as it sits now and I'll be cutting it just past the O2 sensor for install in the car and will then field fit the exhaust system at that point. I don't expect any clearance issues on the sides.
