Old 02-06-2022, 04:39 PM
Burbach 174 Burbach 174 is offline
Default 1960 389 Freeze Plug size same as all 389's?
I have a corroded freeze plug I need to replace on my 1960. Are these all the same size as the 389's of later years where there were three on each side? Mine has the two large ones on each side of the block. A vendor lists several engines and years for the one kit.. I wasn't certain about this so wanted to check first!
Maybe someone here has one or two they want to get rid of (Sell me) saving me even more time.
The one I need to replace is just over the motor mount on the passenger side. May be easy to remove except I have the AC/pump mounted over it so maybe the proper puller can fit in there..
Thank you!
Old 02-07-2022, 12:14 AM
Steve Barcak's Avatar
Corroded/? had to be steel than. brass plugs never do that. ALWAYS use brass. not a place to compromise.
Either 1 15/16" or 1 61/64" both work fine.
Hope this helps you
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 02-08-2022, 10:59 AM
Thanks Steve,
That helps.. Yes they were the originals. I'll post a picture later.
Old 07-25-2022, 09:17 PM
Thanks!!
Sure helped - got it done over the winter but here's the video I made of the issue so someone else may be helped. 389 freeze plug replacement the hard way.
Youtube video - Pontiac Freezeplug Replacement
Old 10-13-2022, 01:43 PM
mr67gp mr67gp is offline
Thanks for sharing the video. MY 1957 has one rust perforated expansion plug in the cylinder head, and perhaps another 1 or 2 on the back of the block behind the transmission. Your video is convincing me I should probably pull the transmission and the engine and replace all the freeze plugs.
I just hope I don't find a cracked block instead of a rusty expansion plug when I drop the transmission.
Jim K in PA
1967 GP HT 428
1967 GP convert 428
1957 Chieftain 4D HT
Old 10-13-2022, 09:17 PM
If one is rotted the rest aren't far behind. If you have any chance do them all.
The Following User Says Thank You to Goatracer1 For This Useful Post:
