Old 09-16-2013, 05:22 PM
Half-Inch Stud's Avatar
Default 4L80 Mech Speed Tail Cups
The Mech Speedo Tail Cups are available as Custom castings for $600 +/- $75 from the Internets.
I'm in process with modifying 2 4L80 Tail cups to include the TH400 Mech Speedo port by welding an aluminum tube into the casting. Will soon have a cost base. Is there interest in me making more (modifying your part)?
Can also drill PMD Flexplates for the 6-bolt Factory 4L80E Converter.
Post or PM if interested. HIS
Old 09-16-2013, 05:58 PM
ponjohn's Avatar
ponjohn ponjohn is offline
YES...hell yes.
Old 09-16-2013, 07:08 PM
Bnick166's Avatar
Bnick166 Bnick166 is offline
Subscribed.......
Old 09-16-2013, 11:41 PM
jakeshoe jakeshoe is offline
I've seen this tried and still have one made this way. Good luck with keeping it from leaking.
If you need any 4L80E tailhousings, I have a surplus of them I will sell.
www.jakesperformance.com Racing Automatics and LSx Engine components
Old 09-17-2013, 07:21 AM
Jake, thanks again. I passed on your original modified housing (offer) because I was determined to DIY without following another one's process. I noticed that Art Carr also did the Tail cup Mod with welding, and figured OKAY THEN if it's good enough for Art Carr ( and you) then it is worth a try on my junk.
Down the road, I hope to need tail housings to help a few fellas out.
HIS
Old 11-26-2013, 07:21 PM
Slow yet steady. Have 2 Tail Cups done with MECH Speedo. Will Post pictures soon.
If interested; PM me or just send me your Tailcup & $290, I'll get it modified & send it back.
Bead-Blast (for good welds), New Rear Bushing & Rear Seal. I can leave it bare or paint it gray (my usual finish).
If you need a basic 4L80e core Tail Cup, see Jake's Post above. I have only 1 extra.
Old 11-30-2013, 08:51 AM
Trying for 3 photos; Shows clip to hold speedo insert.
Old 11-30-2013, 08:53 AM
Default 4L80 Tail cup
...turned over.
Old 11-30-2013, 08:55 AM
Default another view of 4L80 mech speedo
third photo; shows clips holding the speedo in.
These mods were performed on unprepped cups. So the welds are nice but not perfect (like Marcella's work). These will get my gray paint to match the cases. The welder says that the glass bead prep will allow neat & uniform welds.
Future mods will get the process: glass bead, Rear Seal & Bushing removed, cut & weld, clean, Install New Rear Bushing & Seal. either bare or gray paint finish.
Old 02-20-2014, 02:41 AM
antique69lemans antique69lemans is offline
How is this going so far ?
Do you supply the gearsets, and are they from a th4oo ?
