Old 02-16-2014, 12:05 PM
floffy's Avatar
floffy floffy is offline
Default 2nd gen axle width
Hello,
Can anybody tell me what the width is from a 72 firebird 8.5 10 bolt axle from the OUTSIDE AXLE FLANGE to the other OUTSIDE AXLE FLANGE.
We took the axle apart some time ago and we want to upgrade it with ford large bearings next week but i forgot to measurebit with the axles in.
Thanks,
Daan
Old 02-16-2014, 02:12 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Most GM rears the axle flange is 2.81" past the brake backing plate flange.
Skip Fix
Old 02-17-2014, 01:38 AM
floffy's Avatar
So that would be the casing plus 5.62 for the width?
Can somebody please measure that tombe sure before i start cutting?
Thanks,
Old 02-17-2014, 03:57 PM
Skip Fix's Avatar
Yep. Some GMs are 2.75(Wilwood has different kits for each). My second gen were 2.81 when I measured.
If you are welding on ends you can set total length whatever you want but you need to check your brake system and what it's specs are or they won't fit right be they drum or disc.
Skip Fix
Old 02-18-2014, 01:38 AM
floffy's Avatar
I got discs, brackets from ebay and i think c 10 calipers.
Daan
Old 02-18-2014, 10:25 AM
Skip Fix's Avatar
Daan I can go tomorrow to my storage and measure one but you really need to mock up the disc setup up also to see what distance they were made for. As I said Wilwood has two sets of kits depending on the distance.
Axles are I think 30 1/16-30 1/8" plus the width of the posi cross shaft- as they but against it- can get you there also.
Skip Fix
Old 02-18-2014, 10:49 AM
floffy's Avatar
Skip,
Thanks for helping me out, axles are yukon 30 splin 30 1/16 and posi is an eaton lsd 30 spline.
I will mock up the brackes but to be sure i want tomknow the exact width so if you are willing to measure the axle tomorrow for me you help me out a lot.
Thanks,
Daan Holman
Old 02-19-2014, 02:19 AM
Grand73Am Grand73Am is offline
From wheel mounting surface to wheel mounting surface, I have measured 61-1/2" on the 2nd gen F-body rears.
Steve F.
Old 02-19-2014, 12:49 PM
Skip Fix's Avatar
I'll get a measurement today but with the pumpkin hard to get a straight shot. Put the axles in the posi and measure might be a more accurate way.
Skip Fix
Old 02-19-2014, 11:39 PM
Skip Fix's Avatar
61 1/4 drum to drum. Pumpkin not imn the way much measuring drum to drum like it is housing flange to flange.
Skip Fix
Old 02-21-2014, 11:23 AM
floffy's Avatar
Thanks for the info guys.
Daan holman
The netherlands
