Old 02-19-2014, 04:17 PM
rohrt rohrt is offline
Default Any slick ways to pull out press in studs
As the title says just wondering if there are any slick ways to pull out the press in studs.
heat the boss?
Socket and nut/washer?
Old 02-19-2014, 04:36 PM
Craig Hendrickson Craig Hendrickson is offline
Pontiac performance Author
IIRC, the equivalent of a socket and nut was sold as kit by MrGasket back in the day. That will certainly work. Be sure to use anti-seaze on the nut or you'll ruin it -- or have plenty of nuts available. Of course now you've got to drill & tap the existing hole for a screw-in stud, but by implication, you knew that.
Craig Hendrickson, the "H" in H-O Racing Specialties.
http://www.OriginalHO.com
Old 02-19-2014, 04:45 PM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
Check this out. Good thread vvvvvvvv
http://forums.maxperformanceinc.com/...d.php?t=734861
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
Old 02-19-2014, 05:32 PM
4mula73's Avatar
4mula73 4mula73 is offline
At the machine shop I work at in the summer, we use a slide hammer with the end threaded on the inside so it threads onto the stud. Usually just that will remove them. If it doesn't, we heat the boss with an oxyacetylene rig.
73 Formula. 9.1:1 400 .030" over, TRW forged pistons, hand ported 6X-4s milled to 85cc, Ferrea 2.11/1.77, Crower 68404 springs, 276°/284° 228°/236° @.050 .474"/.474" 112 LSA, Performer RPM, Shaker Tuned Qjet, Hooker 1.75" headers. TH400, Hughes GM25 converter. 4.10 gear for now. 1st Drive: 12/30/16. *SOLD*
74 Trans Am 455 AT Buccaneer Red
Old 02-19-2014, 05:36 PM
makinchips makinchips is offline
i use 5 or 6 hardened washers with grease and an impact gun.
Old 02-19-2014, 11:01 PM
77 TRASHCAN's Avatar
x2, works...
Shut it off
Shut it off
Old 02-19-2014, 11:40 PM
Squidward's Avatar
If you plan on just pulling out press-ins and replacibng them with press-ins, then get some washers, a nut, and have a party. If you want to also tap for screw-ins, then DON'T go hog wild and pull them all. You will need to use one stud of a pair to hold a tap guide in place to tap the other hole. See referenced thread above for the DIY methodology.
Old 02-20-2014, 10:53 AM
Thanks all.
Plan is to replace with screw in studs. I love that jig in the link above but I don't have the time, tools or talent to make one.
