Old 05-23-2021, 08:06 PM
65sport 65sport is offline
Default Steering shaft
So I went to install a new power steering gearbox on my 65 Lemans. To my surprise, it's got a solid (non-collapsible) steering shaft.
I want to make it collapsible, if possible without removing the shaft from the column. I'm open to taking the column out though if necessary.
I was thinking a Borgeson Universal
https://www.summitracing.com/parts/brg-460018?rrec=true
Thinking cut off the splined end of the old one and using a lathe weld it on. On the other end cut off near the existing column and use a coupler, or sleeve/pin.
I'm open to other ideas or critique of my plan.
Old 05-24-2021, 08:25 AM
chrisp chrisp is offline
67 uses a collapsible column & entire column can be adapted .
