690 horsepower pump gas "true" street engine
I came across a post on Facebook in regards to a gentelman inquiring about building a 690 horsepower, 93 octane pump gas, street engine. Using a factory block around 460 CID. This engine needs to have street friendly characteristics so the wife, mother-in-law and girlfriend can run it to the grocery store if needed. Not getting much worthwhile input over there (accept for a guy who explained how to do it, but his own personal attempt came up around one hundred horsepower shy) and get some input, ideas and details from anyone that has done it, come close or thought about it.
I don’t have time for science fiction....
The Following User Says Thank You to 77 TRASHCAN For This Useful Post: | ||
I do not think any stock block engine that makes 700 HP could use a converter than is street friendly.
Maybe if you had the perfect high end set of heads, intake and use electronic fuel injection where you could get it done with a small enough cam ? Or put a turbo on a RAIV cam, done ! |
I think it would be tough. But, if someone found the perfect 455 block and bored it over .100 like Ken at PPR used to do, stroked to 4.25, 12-1 with perfect cam. Lots of lift and around .260-265 @ .050 , 2.25 valve 400cfm High Ports that have been wide ported or the like E head, have Marcella make a tuned port EFI intake with all the sensors and bells and whistles, custom 2" headers with high end merge collectors, . thin metric rings with V pump, trick oil pan with big kick out and scrapper..... maybe they could do it. Put the biggest cam you can that is street-able. Might take a few tries with cam. Might need aluminum rods pushing the CR that high. |
This formula has been scoffed at, but here it is anyway for entertainment value...
Air Flow Research developed a formula based on air flow. It predicts a normally aspirated engine's horsepower potential based on intake-system airflow. But note, and important, according to AFR they state it is based on the net cfm airflow delivered at the valve thru the carb, intake manifold and cylinder head. Not the cylinder head cfm flow itself. The formula..... Horsepower = 0.25714 x cfm at 28" x number of cylinders There are some caveats involved. Actually reaching the predicted power level requires the engine to have the right compression, the right cam, a tuned exhaust, and a nonrestrictive carb and intake manifold. The combined lift generated by the cam lobe and rocker arm should equal the observed lift on the flow bench needed to achieve the desired intake port flow, plus a good exhaust port flow. Etc, etc. 335 cfm equals 689 hp. Again, keep in mind that 335 is air flow delivered to the valve. .
The Following User Says Thank You to Steve C. For This Useful Post: | ||
That is a good middle of the road estimate. Did AFR ever say what CR they based that on? I would think a true street engine would need more like 360 + CFM. Just like xxx MPH @ zzzz weight will take qqq HP. The answer is not the same for a Firebird and a mini van. Stan
I personally think it would have to be something like this...
650 horse, idle all day, no issues with overheating, OEM reliable, etc. But not a Pontiac. |
you cannot do this with a 535, much less a stock block.
i am no engine builder, definitely no expert,but i think 460 cubes is big enough.heads is where i would think would be the deciding factor. its definitely a tall order. probably take 12.1 comp, a cam with right spec. maybe 390 cfm port flow? i only jumped in because i want to learn.
The Following 3 Users Say Thank You to ponchonlefty For This Useful Post: | ||
either that or you have to really stretch the definition of "street friendly." |
A 535 could do it with ease, no replacement for displacement. But a 461 would be tricky i think, it can make the power but just how street friendly will it be.
The Following 3 Users Say Thank You to slowbird For This Useful Post: | ||
that's about 1.3 hp per CID, or about the same as a 600 hp 461. i don't think most wives and girlfriends would think a 600 hp 461 has good street characteristics!
Our 461 makes 610hp and is very street friendly. Power brakes, tighet'ish converter and 3.42 gears. Really is very street friendly
The Following 2 Users Say Thank You to slowbird For This Useful Post: | ||
what heads you running?what compression?
Didn't the 461 you dynoed last summer make 622.5 HP? Stan
A larger cu inch engine could achieve the goal.
The Following 2 Users Say Thank You to ta man For This Useful Post: | ||
These big horsepower ideas and theories are all fascinating but nobody’s addressing the elephant in the room. WHO THE HECK IS HIS MOTHER IN LAW AND IS SHE SINGLE?!?! Sent from my iPhone using Tapatalk |
What would the Road Paver do in your combo?
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports, 3" pypes, Hooker 1 3/4" headers, hydraulic roller, 10" Continental, 3.42 gears 11.5 @117.5mph 3900lbs ([_|_] ##\|/##[_|_]) |
if i really wanted to pull this off, first i would go hydroboost to get rid of the power brake issue. then a wide ratio six speed manual so i have a really steep first gear. big hydraulic roller with light retainers and beehive springs. maybe wide port edelbrocks and a victor? and a chassis that allows headers with big primaries. get the newer chambers to help with octane requirements. and a 4781 with a manual choke. all the cool kids have manual chokes!
