Old 06-27-2022, 10:24 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Default 690 horsepower pump gas "true" street engine
I came across a post on Facebook in regards to a gentelman inquiring about building a 690 horsepower, 93 octane pump gas, street engine. Using a factory block around 460 CID. This engine needs to have street friendly characteristics so the wife, mother-in-law and girlfriend can run it to the grocery store if needed. Not getting much worthwhile input over there (accept for a guy who explained how to do it, but his own personal attempt came up around one hundred horsepower shy) and get some input, ideas and details from anyone that has done it, come close or thought about it.
Go fast, see Elvis!
Old 06-27-2022, 10:33 PM
77 TRASHCAN's Avatar
I don’t have time for science fiction....
Shut it off
Shut it off
The Following User Says Thank You to 77 TRASHCAN For This Useful Post:
Old 06-27-2022, 10:34 PM
Dragncar Dragncar is offline
I do not think any stock block engine that makes 700 HP could use a converter than is street friendly.
Maybe if you had the perfect high end set of heads, intake and use electronic fuel injection where you could get it done with a small enough cam ?
Or put a turbo on a RAIV cam, done !
Old 06-27-2022, 10:39 PM
PAUL K's Avatar
It needs to be naturally aspirated. The converter could be worked around by using a switch pitch.
Go fast, see Elvis!
Old 06-27-2022, 10:45 PM
I personally think it would have to be something like this...
650 horse, idle all day, no issues with overheating, OEM reliable, etc.
But not a Pontiac.
i82much's Avatar
i82much i82much is offline
you cannot do this with a 535, much less a stock block.
Old 06-27-2022, 11:38 PM
ponchonlefty ponchonlefty is offline
Smile
i am no engine builder, definitely no expert,but i think 460 cubes is big enough.heads is where i would think would be the deciding factor. its definitely a tall order. probably take 12.1 comp, a cam with right spec. maybe 390 cfm port flow? i only jumped in because i want to learn.
The Following 3 Users Say Thank You to ponchonlefty For This Useful Post:
Old 06-27-2022, 11:47 PM
i82much's Avatar
you would need a cam so big you would have very little idle vacuum. forced induction is the only way to accomplish this.
either that or you have to really stretch the definition of "street friendly."
Old 06-27-2022, 11:51 PM
i82much's Avatar
if i really wanted to pull this off, first i would go hydroboost to get rid of the power brake issue. then a wide ratio six speed manual so i have a really steep first gear. big hydraulic roller with light retainers and beehive springs. maybe wide port edelbrocks and a victor? and a chassis that allows headers with big primaries. get the newer chambers to help with octane requirements. and a 4781 with a manual choke. all the cool kids have manual chokes!
Old 06-27-2022, 11:52 PM
i82much's Avatar
4032 pistons instead of 2618, too!
Old 06-27-2022, 11:54 PM
slowbird's Avatar
slowbird slowbird is offline
A 535 could do it with ease, no replacement for displacement. But a 461 would be tricky i think, it can make the power but just how street friendly will it be.
The Following 3 Users Say Thank You to slowbird For This Useful Post:
Old 06-27-2022, 11:56 PM
i82much's Avatar
and a light car would make the lack of low end less bothersome.
Old 06-27-2022, 11:59 PM
i82much's Avatar
that's about 1.3 hp per CID, or about the same as a 600 hp 461. i don't think most wives and girlfriends would think a 600 hp 461 has good street characteristics!
Old 06-28-2022, 12:14 AM
slowbird's Avatar
Our 461 makes 610hp and is very street friendly. Power brakes, tighet'ish converter and 3.42 gears. Really is very street friendly
The Following 2 Users Say Thank You to slowbird For This Useful Post:
Old 06-28-2022, 12:29 AM
what heads you running?what compression?
Old 06-28-2022, 12:34 AM
65madgoat's Avatar
I have seen aftermarket blocks achieve 675 to 700 hp/tq and be street friendly get in and drive engines with EFI. Now running one myself. But man would be something to get a stock block to those numbers. Like the OP said, to 600hp it is doable, but to 700 would take some real voodoo magic I feel.
Get an MR1 or IA2 block if wanting a 700 streetable horse and torque build that will last.
The Following User Says Thank You to 65madgoat For This Useful Post:
Old 06-28-2022, 01:12 AM
The turbo stuff was just a joke.
I think it would be tough. But, if someone found the perfect 455 block and bored it over .100 like Ken at PPR used to do, stroked to 4.25, 12-1 with perfect cam. Lots of lift and around .260-265 @ .050 , 2.25 valve 400cfm High Ports that have been wide ported or the like E head, have Marcella make a tuned port EFI intake with all the sensors and bells and whistles, custom 2" headers with high end merge collectors, . thin metric rings with V pump, trick oil pan with big kick out and scrapper..... maybe they could do it.
Put the biggest cam you can that is street-able. Might take a few tries with cam.
Might need aluminum rods pushing the CR that high.
Old 06-29-2022, 09:40 AM
Steve C. Steve C. is offline
This formula has been scoffed at, but here it is anyway for entertainment value...
Air Flow Research developed a formula based on air flow. It predicts a normally aspirated engine's horsepower potential based on intake-system airflow. But note, and important, according to AFR they state it is based on the net cfm airflow delivered at the valve thru the carb, intake manifold and cylinder head. Not the cylinder head cfm flow itself. The formula.....
Horsepower = 0.25714 x cfm at 28" x number of cylinders
There are some caveats involved. Actually reaching the predicted power level requires the engine to have the right compression, the right cam, a tuned exhaust, and a nonrestrictive carb and intake manifold. The combined lift generated by the cam lobe and rocker arm should equal the observed lift on the flow bench needed to achieve the desired intake port flow, plus a good exhaust port flow. Etc, etc.
335 cfm equals 689 hp.
Again, keep in mind that 335 is air flow delivered to the valve.
Old information here:
The Following User Says Thank You to Steve C. For This Useful Post:
Old 06-29-2022, 09:54 AM
ta man ta man is offline
Mine makes close to 600hp and drives smooth, you don't know the power is there until you step on it.
A larger cu inch engine could achieve the goal.
The Following 2 Users Say Thank You to ta man For This Useful Post:
Old 06-29-2022, 09:58 AM
Stan Weiss's Avatar
Steve,
That is a good middle of the road estimate. Did AFR ever say what CR they based that on? I would think a true street engine would need more like 360 + CFM. Just like xxx MPH @ zzzz weight will take qqq HP. The answer is not the same for a Firebird and a mini van.
Stan
Pontiac Pump Gas List
