Old 01-12-2021, 12:54 PM
foxgapLeMans foxgapLeMans is offline
Default Difference between 71 GTO and 71 Grand Prix steering columns
Is there any difference? I have a GP column here with tilt that I would like to put in my GTO, will the mounts be the same or could I take the brackets from the GTO and put them on the GP column and slide the sucker in. Just want to get the correct spacing between the column and the dash.
Thanks all!!!
Old 01-12-2021, 02:18 PM
pggto's Avatar
pggto pggto is offline
I put a 69 GP tilt in my 70. I did this back in the 80's so I don't remember the details, but it fit and still works just fine. I just switched ignition switches. I'm sure there are a few differences, someone will have more info.
Old 01-15-2021, 12:06 AM
A.W.Dille A.W.Dille is offline
I used to have a tilt column from a 72 Grand Prix in my 71 GTO. If I remember correctly it was a simple bolt in swap. But trying to think back about 27 years.
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear
85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book.
87 F350 6.9 4 speed dually
A poor man has poor ways.
Old 01-15-2021, 07:53 AM
Thanks all. This will be todays project. Can't wait to see how it works
Old 01-15-2021, 09:42 AM
John Milner's Avatar
John Milner John Milner is online now
Fairly sure mine was just a bolt in deal as well. I used a 69 gp tilt column in my 69 gto.
Old 01-15-2021, 12:35 PM
vertigto's Avatar
vertigto vertigto is offline
Is this the same for 70? Would love to have a tilt-column in my GTO, of course if I could find one.
Old 01-15-2021, 01:03 PM
It is in and works so sweet! The one thing that does not fit perfectly is the plug for the turn signals and such, flat plug with a bunch of wires in it. It will fit by the end of the day though.
Old 10-31-2024, 11:28 AM
pontiac71 pontiac71 is offline
What did you need to do to make the plug fit?
Thread Tools
Display Modes
