SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Old 08-03-2023, 12:39 AM
Joe-Touring Joe-Touring is offline
Default 400 Pistons/Rods Ross/Childs&Albert new f/s
New pistons/rods for a Pontiac 400. 4.15 Ross forged pistons. Flat tops, 8cc valve reliefs. Bought from KRE. Childs&Albert forged rods. Rods are press fit. Rods are quite old but appear to be unused and gorgeous. My machine shop installed the wrist pins and used them for mock-up to measure deck height. My crank turned out to be junk, now I'm going with a 433. Would love to use the rods but don't want to press off the pistons. Comes in original box, with all Ross docs, bob weights specs for balancing and torque specs for rods.
$1000 plus shipping. Located in Western WA
67 LeMans, 326, M20, 3.31 12 Bolt
Old 08-03-2023, 12:40 AM
Old 08-15-2023, 02:39 PM
Bump, $1000 shipped
Old 08-15-2023, 04:27 PM
mysticmissle's Avatar
Do they come with rings? What are the ring groove widths?
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 08-15-2023, 07:39 PM
Ring groves are 1/16 1/16 3/16. I fit the top rings to my block, so I wasn’t gonna include em. Planning on buying another set of Ross pistons and using those rings for a 4” stroker build
Old 08-15-2023, 08:18 PM
Did you slide them in your block what was the piston to deck Height ? Was your block decked? Do you have the piston spec sheet
1964 540 gto
Old 08-15-2023, 09:34 PM
I didn’t measure myself, but my machine shop did. I had my block zero decked, didn’t ask how much they cut. They do come with a spec sheet and bob weights from when I had my crank balanced. Using the spec sheet I calculated a 10.22” deck height.
Old 08-16-2023, 07:30 AM
An you post it the sheet please
1964 540 gto
Old 08-19-2023, 03:41 PM
Here ya go:
Old 08-24-2023, 01:21 PM
Bump
The Following User Says Thank You to Joe-Touring For This Useful Post:
Old 09-04-2023, 04:00 PM
Bump, also decided to include the rings. Top rings have been fitted, should be able to buy a top only set from Total Seal. The bag has the part number on it
Old 09-27-2023, 03:39 PM
Ttt
Old 10-12-2023, 04:24 PM
$900 shipped
Old 11-08-2023, 04:14 PM
$800 Shipped
Old 11-08-2023, 07:02 PM
grandam1979 grandam1979 is offline
Stock Pontiac on big end of rod for a stock crank?
Old 11-08-2023, 09:20 PM
That’s right
Old 11-13-2023, 01:33 PM
Pending
Old 03-30-2024, 02:46 PM
Sold, thanks PY
