Can anyone out there provide us with any tips or tricks to use when swapping the top of the Rad support to the GTO lower?
They dont reproduce the Lemans Rad Support so I bought the GTO model and saved the top from the original Lemans. The new piece comes from Taiwan, and is a bit thinner in material so they spot welded it 82 times as apposed to the original 36 spots on the top of the Lemans. Looking for any guidence from the experience you may have on doing this project. TIA |
Not sure if this is what you are asking, but If I was trying to graft the bottom rail of one rad support onto another and make it look "factory", I would drill out all the spot welds, get the bottom rail off, weld in all the holes on both pieces, grind the welds smooth, then punch new holes where your want the plug welds to be, and weld the rail to the rad support.
There is a special pair of pliers with a copper pad that you clamp under the spot weld hole that makes it easier to weld in the holes you drilled. https://www.amazon.ca/Steck-Manufact.../dp/B000RFMAGK Also, when I say "grind down the welds" I do not mean with a grinder, I mean with a 36 grit 2" roloc sanding disc in a right angle air die grinder. This works much faster than a grinder, is easier to use, and creates less heat when grinding.
Michael Oshawa built 1 option Judge that was a real basket case, so I am rebuilding it the way I want. 455 +0.030", SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. Last edited by mrennie; 01-08-2021 at 07:59 PM. |
I know at one time there was an issue with the angle of the support in relation to the bottom rail being incorrect. I remember reading a thread about this with pictures, a search should bring it up.
"Honestly the car will only be there for a few weeks, OK maybe a month at the most" |
http://forums.maxperformanceinc.com/...d.php?t=835789
I started that thread, but I'm not sure if the problem applies to 1970 models. It may be that the 68-72 repops were designed for the 1970 and later models and are just improperly sold as working for 68/69 models. |
T hanks all for the interesting tips, sorry I wasnt clear, Im replacing the top of the core support removing the GTO and replacing it with the Lemans as it has the"Peak to support the Beak"as it were.
The bottom left vertical leg and bottom rail were eaten away by the battery acid and rust. I took care of the spot welds with a spot weld cutter, cleaned the parts up and painted the inside surfaces I won't be able to access once welded together. I have a bit more wear and tear to fix up on the top original shelf, then I'll spot it all back together using rosettes welds and then not them down to look real close to what the spot weld looked like from factory. Wish me luck! |
The Following User Says Thank You to Farrell in Vancouver For This Useful Post: | ||
You should be fine ... the problem with the repop supports was all in the lower rail that sits on the bushings, which you will not be replacing.
Post pics of your results. |
![]() Quote:
In my case, I am indeed replacing the entire lower section of the core support, and the only stock PONTIAC part will be the top shelf as it were. It seems the leaking battery (probably over-charging), ![]() So if I purchased a part that will cause me more trouble, I'd like to know now. |
You can check the thread in post #4, it explains in detail what the problem is with the support for 68 and 69, I'm not sure if it applies to later models.
The OEM support in 68 and 69 is at a 10 degree angle forward at the top. The bottom rail should made so it is flat with the ground when the support is tilted 10 degrees, instead many of the repops have a bottom rail that is parallel with the top instead of at an angle. They can be forced to work, but it screws up the core support to frame bushings and makes things like fender alignment a real pain. The 70-72 have substantially different body work than the 68 and 69 ... could be the repops are made for those three years and vendors just assumed they fit the earlier years too. Have the current repops been retooled? I don't know, and for some reason all the vendors seem reluctant to address the question. I don't have a 70 or later model to compare the OEM pieces. One thing you can check is ... look at your OEM support ... is the top slanted down in the front? Is the bottom rail parallel with the ground front to back? (can be hard to tell since it's narrow). If so, then you could have problems with the repops. This thread http://forums.maxperformanceinc.com/...d.php?t=835789 has quite a few pictures which should clarify the situation. If you are desperate for a support ... sounds like you probably have the necessary tools and skills to modify the repop to work anyway. That's what I did. |
68-70 should all have the same forward tilt. I believe the only different between the 3 years is the 68/69 do not need the bent up section of the top rail where the rad shroud attaches, as they uses a metal top panel to attach the rad compared to the 70 that uses the plastic shroud to retain the rad.
I believe the difference between the 70 GTO and Lemans is only the top rail. Again, not 100% sure, but basing this on seeing them years ago. If you are looking at a repop 68-70 support, hold the bottom rail flat on the floor as dataway suggests...if the sides/top are leaning forward, you have a good chance of an easy fix to simply graft on your top rail. If the top and bottom rails are parallel to each other, you are in for some extra work. ![]()
Michael Oshawa built 1 option Judge that was a real basket case, so I am rebuilding it the way I want. 455 +0.030", SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. |
To add a note to what mrennie said.
When you stand it on the floor you have to use a 2x4 or something under the bottom rail, there is a lip on it that prevents it from standing up. See photo. Photo shows a repop .. if this was an OEM piece it would not be standing straight up like that. Note the metal blocks I have underneath to support it by the bottom rail without the lip interfering. It's a hard situation to describe with words. That bottom rail has to be parallel with the ground to sit flat on top of the frame mounting bushings, but the support should tilt forward 9-10 degrees, the lower radiator mounts that attach to this bottom rail are tilted to the back to position the radiator straight up and down, the repops have the bottom rail parallel to the top ... so when you tilt the support forward 9-10 degrees it does not sit on the frame bushings flat like it should. If you force it ... it raises up the whole support which raises up all the sheet metal attached to it. I think some people do this, and then just crank down on the frame mounts so much it pulls it back down, which makes for another bunch of issues. Last edited by dataway; 01-15-2021 at 04:41 AM. |
![]() Quote:
Thanks to allfor the excellant responses.
I compared thr two :stock unit-repop lower and they both sit on the floor the same so this seems to be a non-issue at this point. Once I get this altogether I'll post some pix to see what you guys think. |
Yeah, keep us informed, I'm very curious if this is a 68-69 problem or maybe they have changed the tooling.
Did both of them stand straight up, or were they at an angle when the bottom rail was level with the floor? |
Thread Tools | |
Display Modes | |
