#201
Any new pictures? As I'm starting my own restoration on my 1973 formula - your pictures are going to be EXTREMELY valueable. Thanks and GREAT WORK!
follow me on Twitter @albertpenello --------------- 1972 Firebird Formula 1965 Ford Mustang 1965 Oldsmobile 442 1968 Pontiac GTO 1968 Dodge Charger 1972 Chevrolet Vega (V8) 1973 Corvette Stingray 1978 Pontiac Trans Am 1980 Triumph Spitfire 1983 GMC A-Team Van |
#202
Not much new.
Still wrestling with exhaust manfolds to satisfy myself and Gardner Exhaust... I have ordered my second set of "Ram Air" exhaust manifolds and am going to use the ones from Ames. Here are a few side by side, the RARE models are the darker coated (and scratched) ones: and the fit of the new ones from Ames:
chuck... 1973 455 TA (07A) |
#203
Hard to see in the pictures. Do yo like the fit of these better than the other ones? What's the outlet size?
#204
I do like the fit better.
The outlet size is the same, although it appears bigger on the RARE manifols, they are both supposed to be the stock 2.25" ? I think.. Honestly, Eric (I think) from Gardner flat refused to buld an exhaust for the manifold if it had the 3 bolt flange (like RARE has) and insisted it wouldnt fit right unless I use the 2 bolt flange..so thats what I ordered. Now I can get on with the rest.. All the rear trim (tail panel/ lights/ bumper) is ready to go back together, so thats next.
#205
I delt with Gardner several years ago on my Olds 442. Those guys do AMAZING work but they will not make even the slightest changes. I asked for one small change to the exhaust system and it took forever to negotiate that with them...
Are you going to be able to use the stock starter with those? I'm thinking about the same modification but I want to use the stock starter...
#206
Enjoy the new beer glass they send with the exhaust! It was pleasure, after 3 systems on my car, to install one with absolutely ZERO mods needed. |
#207
Glad to hear positive Gardner comments. He seemed to know his stuff when talking to him.
I may run the stock old starter just to see how it performs. If everything seems OK I may just paint it up. If not, I will swap it out with a mini unit. It does fit with about a third inch more clearance. The RARE manifolds were touching the shield.
#209
Quick update...but no new pics yet.
The Gardner exhaust is on but still hanging loose until I get the weight on each corner. Nice quality stuff! This weekend: Finally got the upper a arm bump stop snubber things installed...PITA Both (anti) sway bars are in place. Front shocks (delco) went on with no problem I need to slip in the drive shaft, instal the shift linkage,put a few rubber gas lines in place, rear shocks, adjust the exhaust, and I may be done sliding around under this thing, Pics later.
#210
I,ve got a mini on my 73 GTO & it is great, it fits good & give lots of room to do anything you would need to do even hookit up or to take it down if needed.
#211
Those Bump Stop rubbers are a PITA! I would buy 3 if not 4 cause you'll tear at least 1 up installing them!!
74 Super Duty Trans Am |
#212
Original bump stops are still available. They go on easily by hand.
#213
I ended up ruining 3 of these buggers!
2 of them I mangled months ago before I had the a arms mounted. Ripped one more installing them this time. I used a hand file and opened up the slot a bit, more like smoothing the radius. Anyway, all installed: OER brand: Also got the rear tailight harness swapped over: Any sources for the mini starter !
#214
On upper bump stops, I have had good luck letting the weight of the car install them for me.
1. Jack up the suspension 2. Start the bump stop in with lots of silicone lubricant 3. Slowly drop the suspension and the spring pressure will push them in place Works every time without issue.
Bob Woodard Brighton, MI 2012 SRT8 Charger - 12.70 @ 111mph |
#215
Not Mine.........I tried soap, silicone, exc.............and had a He!! of a time.
