Old 06-08-2012, 08:09 PM
Radman's Avatar
Radman Radman is offline
Default Headder bolts
I spent 5 hours last ningt putting the gaskets between the engine heads and the exhaust headders. Most of that time was on the @@#%^^&&*!!!! rear center bolt on each side. Gonna make a special wrench for them.
Old 06-08-2012, 09:24 PM
tom s tom s is offline
D ports?
Old 06-08-2012, 09:31 PM
mechanickeith's Avatar
I use this kind of bolt on my hedders. No issues what so ever. Only thing I did was to shorten the end of the allen wrench a little bit!!
http://www.mcmaster.com/#socket-head-cap-screws/=hw889s
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 06-08-2012, 09:50 PM
Radman's Avatar
That would not work for the location. Headman shorty headers. Guys did not want the headers tightened down until the engine/trans was in the car. The bolt is captive between the pipe and the flange. No go for a socket, rachet box, or a normal box. Drivers side the steering column shaft blocks the side access. Did it from under the car 1/12 of a turn at a time with a short open end wrench. Going to get the longest straight combination box/open end. Grind it thin both ways, then bend it at about 1.5 inches from the box end 45 degrees.
Old 06-08-2012, 10:05 PM
beemergary's Avatar
I like 12 points-But have to use hex in the center and have the bolts in the holes before installing. Have a custom made hex wrench also. Make sure your bolts are not too long and bottom out before going tight against the flange . On a couple restorations the headers were on the engine in the front crossmember engine cradle and just lowered the body down over every thing-put in the six bolts and bolted up the trans-crossmember. I used Hooker 68 GTO D-ports. Fit Great
Old 06-08-2012, 10:47 PM
vin63's Avatar
vin63 vin63 is offline
That one can be a little tough. I use an older style small integrated washer hex bolt. This is my 462 in my truck and it does get a little rough at times. My long Mac knuckle saver box end wrench works the best, and I do have to access from underneath.
1963 Tempest Convertible
Pontiac-Powered Funny Car:
400 block, Littlefield 8-71 blower, Enderle injection,
custom blower intake, three-disc glide clutch, three-speed Lenco
Old 06-08-2012, 10:51 PM
blueghoast's Avatar
The best and only way to do this and make it a lot easier is,
Test fit your headers on an engine stand. Nothing is in your
way and you can dimple the tubes a little and test with a
wrengh boxed or opened end. I won't install headers without
doing this first. It's just to hard trying to fit a new set of
headers for the first time in the car. Hope this helps in this
situation as every one knows what a pain headers are to install.
GT.
Old 06-08-2012, 10:54 PM
blueghoast's Avatar
They do make a header bolt with a 3/8 head on it also.
Theres a lot more room using a 3/8's wrengh compared
to a 7/16 wrengh.
GT.
