Closed Thread
Old 01-02-2012, 11:19 AM
niceta's Avatar
niceta niceta is offline
Default My 73 T/A's Journey from 1973 to now
Originally bought from Taber Pontiac in Atlanta, GA. The car was inspected in July 2, 1973. It was registered by owner living in Clarkston GA in 1976 (I have the registration). Not sure if he was the original owner. Not sure how many owners it went through after this point.
It did not make it very far from it's original sales point (330 mi) when I bought it in 2007 from Greensboro, NC.
I am doing full restoration and started in 2008. Just completed painting the underbody. It has been slow going to this point but picking up speed.
http://maps.google.ca/maps?f=d&source=s_d&saddr=Atlanta,+GA,+United+Stat es&daddr=Clarkston,+GA,+United+States+to:Greensbor o,+NC,+United+States+to:48.55233,-109.66866+to:Red+Deer,+AB&geocode=FQP4AgIdclf4-imNCZNpXQT1iDELYwuZL97-Zg%3BFY3kAwId5Zr6-im_ogD6RKj1iDFkHC1AMj5AMw%3BFbtsJgIdmXg--yl5e8c4PxlTiDHIEr54lMS5kw%3BFYrZ5AIdzJZ2-Sk_cF9vQ7NqUzEpj4rAJJpcYw%3BFfWGHQMdyYM3-SmZkhFHKVR0UzGwRBZEkKMABQ&hl=en&mra=dvme&mrsp=3&sz =6&via=3&sll=47.945786,-111.269531&sspn=7.006764,19.665527&ie=UTF8&ll=49.1 5297,-115.356445&spn=13.691803,39.331055&z=5
73 TA 468 5sp SS 700, 12 bolt moser 373, 4 wheel disk brakes.
https://www.facebook.com/media/set/?...7567172&type=3
The Following 2 Users Say Thank You to niceta For This Useful Post:
Old 01-02-2012, 11:30 AM
niceta's Avatar
Some pics of the car before I received it.
Name:	trans am 3.JPG
ID:	268968   Click image for larger version
Name:	trans am 5.JPG
ID:	268969   Click image for larger version
Name:	trans am 6.JPG
ID:	268970   Click image for larger version
Name:	trans am 7.JPG
ID:	268971   Click image for larger version
Name:	trans am 9.JPG
The Following User Says Thank You to niceta For This Useful Post:
Old 01-02-2012, 11:41 AM
niceta's Avatar
Some pics from the underside after cleaning and before cleaning. Thought things looked good no evidence of rust.
ID:	268973   Click image for larger version
ID:	268974   Click image for larger version
ID:	268975   Click image for larger version
ID:	268976   Click image for larger version
Old 01-02-2012, 11:46 AM
niceta's Avatar
Then I opened the trunk up and pulled the carpet back to my horror. Ouch!
ID:	268978   Click image for larger version
ID:	268979   Click image for larger version
ID:	268980   Click image for larger version
ID:	268981   Click image for larger version
Old 01-02-2012, 11:53 AM
niceta's Avatar
And after pulling the lights more suprises, this one I did not like the looks of. At this point I was not sure if I should cut my losses or not.
ID:	268983   Click image for larger version
ID:	268984   Click image for larger version
ID:	268985   Click image for larger version
Old 01-02-2012, 12:01 PM
niceta's Avatar
taking front bumper off as well as the goofy fender flares.
Name:	front fender.jpg
ID:	268987   Click image for larger version
Name:	LR fender.jpg
ID:	268988   Click image for larger version
ID:	268989   Click image for larger version
Name:	stripped nose front.jpg
ID:	268990   Click image for larger version
Name:	front bumper.jpg
Old 01-02-2012, 12:11 PM
niceta's Avatar
Found some more carnage while stripping the car.Looks like the car was hit or hit something on the right side in earlier life. Looks like a right rear quarter replacement. The right rear quarter behind the wheel also needs replacing.
ID:	268992   Click image for larger version
ID:	268993   Click image for larger version
ID:	268994   Click image for larger version
Name:	LR quarter behind wheel.jpg
ID:	268995   Click image for larger version
Name:	LR quarter in front of wheel.jpg
Old 01-02-2012, 12:27 PM
niceta's Avatar
Started on the left rear quarter, cutting out the rust behind the rear wheel but decided I would repair the window channel first
Name:	rear window channel.jpg
ID:	268997   Click image for larger version
ID:	268998   Click image for larger version
ID:	269000   Click image for larger version
Name:	window trunk channel.jpg
Old 01-02-2012, 12:33 PM
niceta's Avatar
This is the 70-73 camaro peice I will use for the window/trunk channel replacement
ID:	269003   Click image for larger version
ID:	269004   Click image for larger version
ID:	269005   Click image for larger version
ID:	269006   Click image for larger version
Old 01-02-2012, 12:46 PM
niceta's Avatar
I had to take alot of time with a straight edge, a measure tape and a sharpie to decide where the body line was the same and where it changed. It was not far from the window/trunk ledge/channel. About 1 1/2"-2". The window and trunk channel are the same on the 70-73 camaro as they are on the firebird. The rear tail is slightly different where it transitions into the tail light.
ID:	269009   Click image for larger version
ID:	269010   Click image for larger version
ID:	269011   Click image for larger version
ID:	269012   Click image for larger version
Old 01-02-2012, 12:56 PM
niceta's Avatar
2nd part of window/trunk channel repair
Name:	Nov 25 09 020.jpg
ID:	269015   Click image for larger version
Name:	Nov 25 09 021.jpg
ID:	269016   Click image for larger version
Name:	Nov 25 09 022.jpg
ID:	269017   Click image for larger version
Name:	Nov 25 09 023.jpg
ID:	269018   Click image for larger version
Name:	Nov 25 09 025.jpg
Old 01-02-2012, 01:15 PM
niceta's Avatar
finish weld
ID:	269020   Click image for larger version
Name:	Nov 25 09 030.jpg
ID:	269021   Click image for larger version
Name:	Nov 25 09 031.jpg
ID:	269022   Click image for larger version
Name:	Nov 25 09 033.jpg
Old 01-02-2012, 01:19 PM
niceta's Avatar
first coat of all metal filler
Name:	rear window channel first coat of allmetal.jpg
ID:	269024   Click image for larger version
Name:	rear window channel first coat of allmetal 2.jpg
ID:	269025   Click image for larger version
Name:	rear window channel first coat of allmetal 3.jpg
Old 01-02-2012, 01:30 PM
se428bandit's Avatar
se428bandit se428bandit is offline
I thought i remember hearing about that car (or car like it) back in the 80's. A friend of mine told me about a T/A that was in Atlanta off of Moores mill rd. Here is a pic of the original Indian that was on the top of Tabers building,it is now at a Cobb Co high school.
Old 01-02-2012, 01:36 PM
niceta's Avatar
Trunk pan replacement
ID:	269027   Click image for larger version
ID:	269028   Click image for larger version
Old 01-02-2012, 01:39 PM
niceta's Avatar
That's pretty cool. Would be neat to have that staue now. My hope is to get some sort of memorobilia from the Taber dealership someday.
So how was the car described do you remember? just curious when the restore was done ie) the fender flares lol. The 80's sound about right for those disco flares lol
Old 01-02-2012, 02:06 PM
niceta's Avatar
More trunk, anyone who has done a trunk knows how labour intensive this can be.
I had to fabricate the outer rear portions as well as the rear 1/2-3/4" peice that has the lip as the repro falls short here. It would have been quicker to go with the full trunk pan but 3X more expensive.
My back is still sore from this job and just like these pics it seemed like it would never end lol.
Name:	left side rear trunk.jpg
ID:	269038   Click image for larger version
ID:	269039   Click image for larger version
ID:	269041   Click image for larger version
Name:	right side rear trunk.jpg
Old 01-02-2012, 08:41 PM
REEDRACER's Avatar
REEDRACER REEDRACER is offline
niceta, That's some nice fab work your doing. Keep it up, it will look sweet when your done. Someday maybe I will own one.
69 Judge RAIII 4SP 2ND OWNER
63 Catalina 421HO 4sp
73 Trans Am 455 4sp
http://www.sdperformance.com/
Drag racing. An adrenalin rush like no other. It felt like going into combat, tasting your first beer, and losing you virginity, all in about 8 seconds.
Old 01-02-2012, 10:29 PM
Formulabruce's Avatar
Nice work!! You going right after it!!
Old 01-02-2012, 11:18 PM
niceta,
looking good. what brand is the 3 piece trunk panels you are using?
Closed Thread
