Old 07-10-2018, 12:42 PM
scott70's Avatar
scott70 scott70 is offline
I had my #64's which are original to my car cnc ported by SD and they are factory rated at 87 but with a slight deburring of sharp edges in the chambers cc'd in at 93.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 07-13-2018, 10:31 AM
72projectbird's Avatar
We got the car torn down yesterday. We'll be detailing the engine bay, painting the frame and other misc components. After we're done painting, the car will be going off to the body shop!
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 07-13-2018, 11:47 AM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
Awesome! Luv to see progress.
Going back with green, or? Vinyl top staying?
Eric "Todd" Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
'67 Tempest Wagon (428/TH400/2.56 posi)
Deuteronomy 8:3
Old 07-13-2018, 12:43 PM
A triple green '70 was the first GTO I ever rode in.
Old 07-13-2018, 01:27 PM
Nope, going black on black, with no vinyl top.
1987 Grand National
Old 07-13-2018, 06:00 PM
Got the frame degreased, sanded, and painted along with the firewall. The booster/master will be changed, and things like the tie rods, dust shields, and sway bar will be painted in a grey color.
1987 Grand National
Old 07-13-2018, 06:50 PM
Held for Ransom's Avatar
400 frame motor mounts.
So long, farewell.
Old 07-13-2018, 07:40 PM
Whats the difference between the two? I know the original mounts are still mounted to the other engine.
Here's two pics of the 455 I took out of the car. I was told it was a 70, but I think it's a 71 block. I thought I took a pic of the build date casting, but I don't see it. I'll grab it tomorrow.
1987 Grand National
Old 07-13-2018, 07:49 PM
johnta1 johnta1 is online now
That is a 1971 455.
Old 07-13-2018, 08:18 PM
That is a 1971 455.
Yes, the one in the car is a 71 455. The guy who was selling the car thought it was a 70, but it's a 71.
The 70 455 is in the corner of the garage.
1987 Grand National
Old 07-14-2018, 03:13 AM
The 455 mount plates on the frame are wider (picture below). Visually quite obvious compared to the smaller upside down triangle shaped 400 mounts.
They require the 455 engine mounts which bolt to the block with 3 bolts (instead of 2 bolts on 400's). I think it's about a 6" engine mount bolt versus 4" or so for the smaller engines. Stronger mount for the additional torque of the mighty 455's.
I'm curious what your build date is on that 71 block. I have a strong interest in early 71 castings.
Eric "Todd" Mitten
Deuteronomy 8:3
Old 07-14-2018, 12:22 PM
Good to know, thanks for the info!
I'll grab a pic of the 71's build date today. I'm degreasing and painting it today.
1987 Grand National
Old 07-14-2018, 07:45 PM
Got the engine all degreased, power washed, and painted up! I grabbed some pics of the casting numbers on both engines. The blue engine is the one currently in the car, with the Chevy orange engine (yes, I know) being the supposed original.
From what I've gathered, the orange one is a late 69 build judging by the date code near the distributer (the car was a late 69 build). It's a YA code, casting number 9799140, which if I'm reading right comes back to a 1970 455 automatic GTO. The heads are 64's.
I cant read the VIN stamping. The top half of the numbers are missing. Is there any way to help get them back some, so I can read them?
1987 Grand National
Old 07-14-2018, 08:48 PM
What's the VIN of your car?
The engine VIN is hard to read, but it can be partially figured out.
If it's close to what the car is it could be the original?
To me it could be possibly 20P118511, the 20 would be for the 1970 model, The P is about the only thing that might match the partial stamp.
The 8 and 5 are kind of guesses, but think the date would be around the 8, the 5 looks a little different on the bottom.
The 1 and 1 on the end are probably the only thing to fit there?
Old 07-14-2018, 11:40 PM
It probably don't match the vehicle's VIN, as I pointed out the frame mounts are not 455 mounts. I think the partial VIN on engine is from a Oshawa vehicle.
So long, farewell.
Old 07-15-2018, 07:29 AM
That's probably correct because of the mounts.
And the 'P' being a '1' is very possible.
Old 07-16-2018, 03:25 PM
Quick question:
On a black Judge, sometimes the stripes look Yellow/Blue/Pink, but I've been reading that it's supposed to be Yellow/Red/Blue.
I really like the pink portion of the stripe, but I don't see any aftermarket companies that offer the stripe in the Yellow/Blue/Pink option. Where would one acquire such a stripe?
1987 Grand National
  #38
Old 07-17-2018, 03:29 PM
We're waiting around for parts, so little things are getting done. The radiator got stripped and polished for that 60's-70's custom look, the interior is gutted in preparation for paint and new covers. The top was removed, and it's not going back on. The coolest thing of the bunch is the new wing!
1987 Grand National
  #39
Old 07-17-2018, 03:31 PM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
Awesome. i just made a thread on a 70 455 GTO I had the PHS to. Then I see this thread and that you're in MA lol. Too funny.
  #40
Old 07-19-2018, 05:54 PM
So, I'm assembling the accessory drive, and I've hit a speed bump.
I cant get the alternator and PS pump to line up with the pulley on the water pump. The two belts are on an angle, with the alternator leaning backwards slightly. I cant figure out what I need to change.
1987 Grand National
