Old 01-19-2019, 06:19 PM
Bill Miksich Bill Miksich is offline
Default 67 catalina rear end
can anyone tell me if a 69 full size rear end will fit my 67 catalina?
thanks , Bill
Old 01-21-2019, 09:57 AM
mr67gp mr67gp is offline
Spring seats will probably be different, and maybe shock mounts, but it will physically bolt in.
Jim K in PA
1967 GP HT 428
1967 GP convert 428
1957 Chieftain 4D HT
Old 01-21-2019, 12:05 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
I believe this is correct. 1967-1968 spring seats are one way, 1969-1970 are another. It's not an insurmountable problem if my hazy memory is correct.
Old 01-21-2019, 02:03 PM
ScottP's Avatar
ScottP ScottP is offline
Don't forget about the control arms. The 69-70 fullsize rears use lower control
arms with both bushings in the arms. The 65-68 have the frame side bushing
in the arm, and the rearend side bushing in the rearend housing. You'll need
the '69 lower control arms for the swap.
Its not a direct bolt-in, but with a few additional parts from the donor car, it
can be done.
-Scott
70 Bonneville convertible, Vortech V7 YSi supercharged EFI455 + 4L80E
Old 01-21-2019, 09:51 PM
Default Catalina rear end
Thank you all. THIS INFO IS JUST WHAT i NEEDED!
Old 04-14-2019, 07:45 AM
Mudtrux's Avatar
Mudtrux Mudtrux is offline
What type/model rear is correct for a 67 Catalina/Ventura?
I'd like to add a Loc-Rite to mine and maybe find a similar axle that would have the 4.75 bolt pattern.
Am I just grabbing at straws?
Thanks,
Old 04-14-2019, 08:03 AM
shaker455's Avatar
shaker455 shaker455 is offline
I'd like to know as well.
Carburetor building & modification services
Servicing the Pontiac community over 20 years
Old 04-14-2019, 06:26 PM
Mudtrux's Avatar
Sorry if this is a dumb question, I don't know how to effectively use the search function.
Seems like I always end up down rabbit holes (Like I do on YouTube)
Is my car a std ten bolt or like a Olds 12 bolt (a modified 10 bolt)??
Old 04-14-2019, 07:48 PM
Ben M.'s Avatar
"12 bolt differential in a 10 bolt case" is how I hear it described.
Old 04-16-2019, 09:18 PM
67GP428's Avatar
67GP428 67GP428 is offline
I have a 67 diff out of a car if you need a pic.
1965 Pontiac 2+2 421 HO auto
1967 Pontiac Grand Prix 428 4 speed- sold
1968 Firebird 400 auto - sold
1967 Bonneville Brougham 2 dr. hardtop. 1969 AMC Rebel SST wagon-sold
Old 04-18-2019, 07:09 PM
Mudtrux's Avatar
I guess I would need the axle (or side gear)spline count? Lockrite list two options. A 30 spline and a 28.
Thanks for the reply.
Would you know if this is a "C"clip type of axle in this diff, or the bolt on style at the end of the tube?
Old 04-20-2019, 01:46 PM
67GP428's Avatar
Bolt on style.
Old 04-23-2019, 07:16 PM
Mudtrux's Avatar
Thanks.
Old 04-24-2019, 12:52 PM
I think the axle is a Pontiac 8.875" or 8 3/4" axle. 12 bolt ring gear, 10 bolt rear cover. Same ring gear diameter as a Chevy 12 bolt, but not the same ring gear as a Chevy 12 bolt. Bolt in axle retainers as already stated.
Old 04-26-2019, 07:10 PM
Mudtrux's Avatar
Thank you very much!
Now to find out if the loc-rite will fit
Old 04-28-2019, 09:31 AM
I typo's sorry it should say Pontiac 8.875 or 8 7/8" axle. My 78 Catalina has the 8 3/4" version. sorry.
