Old 04-25-2019, 04:18 PM
Hangn69 Hangn69 is offline
Default Help needed
I have the right hand kick panel out of my 69 Catalina wagon and it has a strange gasket on the back that is in need of replacing ,any suggestions on what to use as I cant find a replacement anywhere
Old 04-25-2019, 04:41 PM
242177P's Avatar
242177P 242177P is offline
It's probably just dum-dum?
Old 04-26-2019, 03:11 AM
Its a thick rubber gasket stapled to the kick panel/ AC inlet on the passenger side but mine is leaking causing the passenger foot well to fill with water when it rains
Old 04-26-2019, 06:07 PM
Stuart's Avatar
Stuart Stuart is offline
If water is getting in, I think the gasket you're talking about is not the problem - the interior kick panel isn't the spot where water is kept out of the interior. I suspect it's coming in from somewhere else, maybe a leaky windshield gasket.
Old 04-29-2019, 12:09 PM
Is rain getting in when you are parked or when you drive? The kick panel vent gasket is more about keeping cold air out in the winter, it also helps keep splashing out but that would never be significant especially when parked. I'd look at the base of the windshield for gasket or corrosion issues. Another problem is a blocked drain hole into the front of the rocker. This can fill the lower cowl with water and or a rust through at the base of the hinge pillar allowing water into the interior
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
