Old 05-11-2019, 07:28 PM
grd777 grd777 is offline
Default Help with a fuel pump
Looks like I have a oil leak near the fuel pump. I changed the gasket and tighten the bolt could be leaking from there or somewhere else . Seems odd it would leak oil from the fuel pump any help would be great
Old 05-11-2019, 07:32 PM
Bentwheelbob's Avatar
What year is your car what engine does it have?
Old 05-12-2019, 08:42 AM
Sorry a 1975 t/a has a 1970 400 engine
Old 05-12-2019, 05:42 PM
abefromen's Avatar
abefromen abefromen is offline
Supposed to be a special fiber/rubber coated flat washer under the bolt heads.
Old 05-12-2019, 09:03 PM
do you mean the bolt heads for the fuel pump (both bolts )
Old 05-12-2019, 10:27 PM
abefromen's Avatar
yep.....
Old 05-12-2019, 10:41 PM
abefromen's Avatar
use these washers they are the same.
https://www.ebay.com/itm/Auto-Trans-...EAAOSwkCdcpw4J
Old 05-13-2019, 01:26 AM
Aus78Formula Aus78Formula is offline
Haven't seen that before, specific to Pontiac engines? I guess it seals the bolt shaft hole once tightened, are they open threads into block inner?
Old 05-13-2019, 05:52 AM
should i use them on both bolts
Old 05-13-2019, 08:41 AM
abefromen's Avatar
Pontiac yes maybe others too.
yes they are open holes exposed to oil.
Old 05-13-2019, 08:43 AM
abefromen's Avatar
yes unless you want it to still seep oil.
Old 05-13-2019, 09:28 AM
1969GiPper 1969GiPper is offline
No. On a real Pontiac V8 engine the fuel pump bolts to the timing chain cover, not the block like a Chevy. Have seen cracks in the side of the aluminum timing cover just above the fuel pump that can leak oil and look like it’s the pump that’s leaking.
Old 05-13-2019, 09:56 AM
abefromen's Avatar
Yes it mounts to the timing cover but the holes are not blind they are open and exposed to oil.
Why do you think special washers are used there? To stop oil seepage past the threads.
Old 05-13-2019, 04:37 PM
great info guys thanks
Old 05-13-2019, 08:50 PM
Held for Ransom's Avatar
Only the inner bolt (closest to the block) goes into an area that might leak oil. If this was a problem, they would have redesigned it years before '70 (or '75).
So long, farewell.
Old 05-13-2019, 09:27 PM
would the oil leak come form somewhere else
Old 05-13-2019, 09:38 PM
How bad is it leaking? Was the surface area gouged? Was the '70 engine rebuilt? Could be leaking from the crank seal and slinging all around and winding up on the fuel pump.
So long, farewell.
Old 05-13-2019, 09:42 PM
very little , when i touch the bolt i feel oil . i had all the gasket replaced
Old 05-13-2019, 11:49 PM
unruhjonny's Avatar
unruhjonny unruhjonny is online now
weird;
I have never seen anything special connecting the fuel pump to the timing cover;
If the oil at the back of the bolt was under excess pressure, I could maybe see it seeping along the threads... but this scenario just sounds funny.
But hey, I've been wrong before, and I did get my car (also my first car) the year it became a classic...
1970 Formula 400
Old 05-14-2019, 05:11 PM
Originally Posted by unruhjonny View Post
weird;
yes it does seem odd . for all the years i worked on fords never seen this happen . but i do think it is leaking from the bolt
Thread Tools
Display Modes
