Old 06-22-2019, 10:51 PM
Default 1955-1957 power brake convertion
Posted this in brake section but thought I'd try here also. Has anyone converted 1955-1957 manual drum brakes to later style dual chamber master cylinder with power? Did you have to move pedal to firewall? What parts did you use?
Old 06-23-2019, 12:24 AM
694.1 694.1 is offline
There is no easy solution here but there is a lengthy tread from an Olds forum. I will try to find it.
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 06-23-2019, 09:28 PM
https://classicoldsmobile.com/forums...55-olds-53873/
Lots of great information here. Let us know how things go.
7th Firebird
57 Starchief
Old 06-26-2019, 12:11 AM
Found one from Speedway Mtrs that is frame mount. It comes complete with bracket for frame, booster, master and new through the floor brake pedal. It can be used with drum or disc brakes. After convention may give it a try. If anyone else is interested PN is 9106005 and price is $250.
Old 06-26-2019, 11:17 AM
And then there is the dual exhaust & X frame....
7th Firebird
57 Starchief
Old 06-26-2019, 07:32 PM
Poncho60 Poncho60 is offline
Weren't there 57s that had factory dual exhausts? How was that routed, thru the x-member? The frame on 57s is technically not an x-frame. True x-frames were only on 58-59-60.
