Ames Customer Satisfaction Forum Post a 'current' compliment, suggestion or issue with regard to an Ames service or product.
Old 04-10-2021, 07:46 PM
scott70's Avatar
scott70 scott70 is offline
Default 455 engine mounts
Any idea if better grade engine mounts might be made for the longer 455 frame mounts?
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 04-19-2021, 04:18 PM
AMES-TECH's Avatar
AMES-TECH AMES-TECH is offline
Ames Tech Staff member
Scott70, currently the best 455 mount available would be the "Mity Mount", part # N242B for 70-73 A-body. These are a steel lock up design that resembles the original rubber. We do have the standard rubber mounts as well (part # N227L & R), along with solid mounts (N243BB). Thanks!
[/SIGPIC]
Old 04-24-2021, 06:10 PM
SD455DJ SD455DJ is offline
Scott, I'm trying out the Mity Mounts on the 455HO in the GT-37. It hasn't hit the road yet, hopefully later this year, but these mounts do set the engine higher above the crossmember with 1/2" clearance. This is double the distance when I had with regular V8 motor mounts (the cheap Korean aftermarket junk) that crushed and allowed the oil pan to rock on the crossmember and rub against the centerlink only after a few years and a couple thousand miles of easy street driving. I do hope these mounts last longer and don't squash like the standard ones. They are wider and beefier no doubt, but hoping they do a better job. I have used the polyurethane motor mounts on 461 LeMans and they are quiet and don't transmit any vibration or noise into the interior, so another possible solution to consider.
Dennis
Name:	Driver_Mity Mount.jpg
ID:	565329   Click image for larger version
Name:	Pass_Mity Mount.jpg
ID:	565330   Click image for larger version
Old 04-26-2021, 12:26 PM
scott70's Avatar
Maybe theyre better now but the mighty mounts from a few years ago i guess didnt fare well to spirited driving. The poly ones I guess have some fitment issues and dont like heat. I read where Ames here had a new/improved motor mount but only the smaller 400 and down mount. The mounts in my car now have been there for years and many launches. Would replace them if someone made a quality type original without going to a solid. I havent measured but I think ive still got a good 3/8" between oil pan and the steering link. Mounts for the longer 455 frame mount definitley arent as popular to the aftermarket
Old 05-09-2021, 07:52 PM
taktikian taktikian is offline
Default Motor Mounts
Just wanted to let members know the 'Torq Loc' mounts now being offered by Ames is a very stout piece. Just received mine for the 400 and they are much beefier in all aspects when compared to auto part stores variants. The stock long bolt will not work however, had to use the Dorman# 81101. Ames I think should offer this.. Read somewhere that these are just Anchor mounts with the name grinded off and a center bolt added. Not so. If you held them in your hand the weight difference alone (when compared to standard aftermarket) would tell you so. Paul
The Following User Says Thank You to taktikian For This Useful Post:
Old 05-11-2021, 10:07 AM
dataway's Avatar
dataway dataway is offline
Just looked at the Torq-Loc mounts .... metal has got to be twice as thick as parts store options ... wish I had seen those before I put the cheapos on mine.
Old 05-12-2021, 08:53 AM
AMES-TECH's Avatar
During the pre-production research and development of Ames Performance OEM-style mounts, extensive fitment and measurement of critical tolerances were executed in an effort to produce the most authentic and best fitting engine mounts offered to date. We appreciate your feed back on the mounts and take into consideration your comments pertaining to the original bolts not cooperating with these mounts. Upon receipt of your concerns, our technicians mocked up some pairs of the reproductions as well as some GM N.O.S. mounts to ensure there was not an issue and rectify it if one presented itself. Our findings were that the GM bolts used originally as well as the N238X “correct-style” engine mount bolts fit and function as intended.
Ames reproduction mounts DO hold extremely tight tolerances between the steel frame side mounts and ears of the engine mounts. This is also present on the N.O.S. mounts. Though the mounts will nest on original frame mounts, we have discovered in the past that it is best to dress the ends of the N245B reproduction frame mounts due to some residual metal from the stamping process that can and will hinder the mounts from completely seating on the body of rubber engine mounts and providing necessary hole alignment to send the engine mount bolts home. We were unable to replicate any issue with the bolts that would require the Dorman bolts to be utilized in their place(s).
Thank you,
Ames Performance Team
[/SIGPIC]
Old 05-21-2021, 04:34 PM
Default Revision on long bolt
I stand corrected. The factory long bolt WILL work. Apparently was using a long bolt from another application. Sorry Ames you were right, Paul
Old 05-23-2021, 11:18 PM
scott70's Avatar
As these sound like maybe the best stock type mounts available,,,thats why I was hoping theyd make a 455 mount version. Havent heard of the greatest results about any of the others available . From problems of strength issues to having fitness issues of letting the engine sit too low.
Smilies are Off
