Some will counter this problem by inserting thin shims between the cap/main rod section, and then resize the rod so when the rod bolts do stretch, there is a little cushion built in when the cap sides pull in at the parting line, they don't wipe the journal of its oil. |
What piston and rod weights or you using in your G's calculations? While your max piston speed numbers are correct I think most here were talking mean (average) piston speed fpm. Stan
The Boss Bird nitro engine had a bob weight of 2419 grams.
Highest piston speed we ever ran was 8288 Mean piston speed and 13,018 max piston speed. All the internal parts stayed attached, aluminum BME rods. This was on a runaway engine with the loss of high gear. Typical piston speed was 5950 mean piston speed and 9346 maximum piston speed. Never had a piston speed or rod related failure in 10 years of running this combination. You do have to run good parts, that's a given. |
The Following User Says Thank You to mgarblik For This Useful Post: | ||
Stan I am not home till tomorrow to check my numbers for sure for you but I recall a stock reciprocating weight of 1255 .
The mean piston speed of a 400 @ 1000 rpm of 620,and of a 455@ 1000 rpm of 700.
I will add that from what I have seen, there is a correlation to piston speed in regards to max power, and where these engines like to operate for max power. Anything more, it often just becomes an unreliable grenade/ or simply starts to lose it's ability to make power per cubic inch at higher piston speeds. It's just not something i let de-ter me from building milder combinations with a lot of stroke. Regardless of piston speed, if a part wants to break, it will, and won't care how much you spent on it. |
I knew that, at least, parts selection would punch a hole in that statement. |
FPS? my bad.
Not trying to criticize but trying to run things on the ragged edge and building a reliable street engine doesn't mesh well, therefore at the root of the problem. Frank
Poncho Huggen, Gear Snatchen, Posi Piro. |
Also whole lot of Crankshaft failures can be traced not to the actual maximum load in kilonewtons that they are dealing with, but from the flexing induced from the condition of the massive loading of full throttle and high rpm and all of that cylinder pressure produced, and then the unloading when getting off the throttle at high rpm and now that amount of crank flexing is not there.
"... I observe building these strokers are not building them with the mentality of a mild combination in mind, hence the stroke in the first place."
Presuming the 4.250" stroke I might suggest the availability, thus the popularity, for it's use in a upgrade or replacement in many builds. High performance or not. The 6.8 rod length it was designed for in it's initial development many yeas ago is a plus. Edit: My comment is regarding the increase over a 4.210" stroke. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 04-11-2021 at 06:08 PM. |
I didn't say you said people are running them on the edge, I said that, in terms of a street engine, not something meant for the track. I'm sure a stroker can run at higher speeds, but at a greater cost, and for what, I believe in using the shortest rod you can, that's all. I get up into the 6k's reliably, all day with factory rods and lighter pistons just cause I can, and it doesn't cost me an arm an a leg. Edit - Not knocking the strokers, just saying, with the forces created, it takes money, a quality build and knowing the intended use. Frank
Poncho Huggen, Gear Snatchen, Posi Piro. Last edited by 4zpeed; 04-11-2021 at 06:50 PM. |
I'm going with the longer rod
https://www.enginebuildermag.com/201...ng-rod-ratios/ Related to piston side loading.... Taken in part from Jim Butler comments, Q&A section, PE magazine March/April 1997: They built two engines for Rodney's '82 T/A street car. Both engines had 455 blocks. One was filled and the other wasn't. The filled block ran 10 to 15 degrees cooler than the unfilled block. It was reported upon tear-down and inspection, the cylinder walls on the unfilled block were seen to be scratched and scored from excess friction. When measured with a dial bore guage, it was found to be out of round. The filled block was smooth and bore round. He confirmed you do not lose significant coolant capacity by filling the block. However, the difference in the amount of friction is much improved. .
Frank PS. I'm gonna go read this an I'll be right back. Edit - 1st of all thanks for that link, I always enjoy learning and trying to figure out the method behind the madness, I do have a better perspective on rod length. OK, so what really surprised me was the side loading, I would have thought that a longer rod would have more just from the way it enters and exits the cylinder. If you look at the you tube video from the earlier link posted, it sure seems to me like the angle would create more force with a longer rod, am I missing summin? All other things seam to make sense, and I liked the information, but with all the torque our Poncho's make naturally, I think I'll stay where I am with my thoughts. https://blog.k1technologies.com/stok...ngle-explained
Poncho Huggen, Gear Snatchen, Posi Piro. Last edited by 4zpeed; 04-11-2021 at 08:03 PM. |
#38
Exactly. The world is a lot bigger when you view it from outside the box. Pontiac is just a brand name, nothing more, nothing less. The math doesn't change because of it.
#39
Seems some are quick to assume they have a unique view with a magic answer, while offering nothing but what's known or been mentioned previously.
I don't see any Pontiac myths about limitations, I see calculations and facts, physics and the build itself will determine the performance and reliability. The knowledge of someones piston speed from a race car is valuable information and appreciated, but may not appropriately correlate to the OP street car. There are builders that will let someone spend $$$$$ when it's not needed, not to mention possibly having to resize "new" rods or turn a "new" crank. Appears the consensus is it depends on the quality of the build, parts used and intended usage, which is no more or no less, what is initially suggested, in addition to calculations posted by Steve showing forces multiplying as the weight increases, with an addition of performance and also additional stroke. My takeaway from the last link FWIW... "As a general rule, large bore, short stroke engines are high revving, high power engines good for road racing and circle track applications. Pro Stock racers also like this combination for drag racing as do NASCAR engine builders. Small bore, large stroke engines, on the other hand, are better for low RPM torque, street performance, towing and pulling, but have limited RPM potential". Frank
