Old 01-09-2012, 09:39 PM
motobone motobone is offline
Default 1965 GTO
Hi-
I'm assisting my wife and her sister in selling their fathers fully restored 1965 GTO. Here is most of what we know about the car. Please email me if you have any questions or would like to see it in person.
This is not a matching numbers car; however, it is a GTO with PHS documentation.
Frame off restoration, commissioned in August 1997 and completed in October 2000, this car was built by Mr. Herman Seymour of HS Classics, in Coppell, TX. He specialized in building GTOs and in the photos you will find the nameplate (mounted under the hood). I have the original bill of sale/ contract to complete restoration.
You will be able to see most of the options in the photos, below are the details of the bill of sale:
Frame off restoration (I have non-digital photos of the frame in the shop)
Drive Train: 389 Tri-Power
Engine was completely rebuilt, using original GTO heads and a replacement 389 block. A restored, original 1965 tri-power intake was used. All engine components, such as water pump, alternator, etc are rebuilt original or new. Engine compartment restored to stock GTO original appearance.
Transmission is a reconditioned Muncie 4-speed with new clutch & pressure plate
Rear end - original 323 posi-track
Power steering, power brakes
Chassis: Frame was stripped to bare metal and painted with all new front end using new parts. New body busings and new brake parts. Wheels are stcok GTO steel wheels using orignial 1965 wire spinner hub caps.
Interior: New headliner, door panels, carpet & seat covers from "PUI" Interiors in orignial Parchment color. New arm rests (front and rear) new dome lamp and all window crank and door handles original (good - used condition).
Exterior: Car was stripped and painted in 1965 Nightwatch Blue using PPG Deltron base coat clear coat paint. Paint is high quality driver. All emblems are correct 1965 GTO original. Front and rear bumper rechromed. All chrome and stainless trim is used original and subject to small flaws.
Options to base GTO:
A/C (cold!)
Four-speed console in good, used condition
Wood sport steering wheel (used 1969 wheel & 1965 horn button)
Ralley gauges
Original distributor modified to eletronic ignition
AM/FM radio conversion package
Power antenna on right hand fender
Handling package
Reproductive exhaust splitter plus hangar
Front disk brake conversion
Front seat belts
The engine was reset to 0 in 2000. There are less than 7,000 miles on the car. It has been garage kept since 2000.
Other items that we have noted:
Good tires
Very clean interior with no rips tears or worn areas
No apparent engine leaks
Recent Oil change (<300 miles ago)
Carburetors adjusted (winter 2010)
New Clutch (winter 2010)
The only non-original item is the 8-disc cd changer - it's mounted in the truck with a remote in the glove compartment.
Everything is working perfectly with the exception of the power antenna - which was working a few months ago - it may be a fuse. There are a few small chips in the paint, mostly around the doors, quarter panel, and the front grill. I've tried my best to these imperfections in the photos. Also, according to the mechanic who replaced the clutch this winter, this car does not have the original "U" joint on the drive shaft. It seems to be fine, it's just not the right year "U" joint.
Here is a link to the photos of the car - there are 97 and I tried to capture the beauty of this vehicle, while also showing that there are a few small imperfections:
http://s59.photobucket.com/albums/g2...965%20GTO/
This was car built to drive - the specifications are intended for a daily driver.
$34,000 asking price
Located in Fayetteville, AR
The car is running great - it purrs!
Thank you. Please send me an email if you would like more information.
More photos here - http://s59.photobucket.com/albums/g2...ne/1965%20GTO/
We've tried to be as honest as possible as to what we know about this vehicle.
Please do NOT send spam or junk email. Only contact me if you are interested in the car.
Old 01-10-2012, 09:31 AM
1969 Ram Air 1969 Ram Air is offline
That's a beauty with a very nice color combination.
69 GTO Judge, Liberty Blue/Parchment, RA3, 4-speed
69 GTO, Verdoro Green, Green, 400, 4-speed
69 Firebird 400, Starlight Black/Black, RA3, 4-speed, 611 RA Inlet
Old 01-10-2012, 10:55 AM
Keith Seymore's Avatar
Very nice; looks like a nice, honest, comprehensive write up; good luck with the sale.
Relative to the power antenna: trying actuating the switch and giving the base of the antenna a few "love taps" with a hammer or hammer handle. Sometimes they get a stuck magnet and will work after a little percussive therapy. If it works then that will at least tell you it's not a fuse or faulty wiring.
K
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
Old 01-11-2012, 11:49 AM
Thanks for the kind comments and emails. I will look into the antenna issue.
Also, we're open for suggestions on pricing and the car in general.
I believe the car was an original 389, but it did not come with the factory tri-power carburetors or 4 speed. However, it was originally sold with the factory air conditioning. The color is not original either.
This car was built for my father-in-law to replace his 1965 Goat that was totaled in the early seventies. It was built to drive and enjoy and after driving this car for a few hundred miles, I see the reason why these cars are so popular. This car turns heads everywhere and I've never received so many "thumbs-up" as I have in the past year. Simply amazing...
I'll try to get it out over the next few days and post some new photos. Maybe even a video or two with a walk around and the sounds of this smooth 389.
Thanks-
Old 01-23-2012, 05:04 PM
Default Videos!
Okay, finally got some videos of the car running to further show off this beauty.
http://www.youtube.com/watch?v=ZyoWhJBrtEM
http://www.youtube.com/watch?v=PmqovXrwTSk
http://www.youtube.com/watch?v=-X1UWt6V1nc
http://www.youtube.com/watch?v=pgkAY-W8UNw
Old 01-25-2012, 08:23 AM
Tim john Tim john is offline
Beautiful car. This will make someone very happy, good luck with your sale.
Tim john---
Old 01-27-2012, 10:53 PM
Default Price Drop
Motivation is increasing - $29,000
Old 01-28-2012, 08:24 PM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
Beautiful car. Love the colors. Good luck with the sale.
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
Old 01-30-2012, 11:05 AM
bastard's Avatar
bastard bastard is offline
I have seen this car and gone for a ride in it.
It is very nice and sounds "right".
Old 01-30-2012, 10:29 PM
Thanks for the comments.
Sold - Pending payment
Thanks PY!
