Old 03-31-2024, 06:03 PM
Default dry ice blasting
Just trying to get an idea on what it cost to dry ice blast the bottom of a car. I understand costs vary etc.... Closest dry ice blaster that I know of is 2-1/2hrs away. It isn't like I can just run it by and get a quick estimate.
Car in question is a '72 Trans Am. Car was undercoated at the dealership when new and was sold new in Wisconsin. It spent the first 3 years of its life there but has resided in California since. The bottom of the car isn't rusty... but is nasty..
1974 Formula 400 - Ram Air automatic
Old 03-31-2024, 07:25 PM
JLMounce JLMounce is offline
I spent some time thinking about setting up a business. In your case you’re probably going to need to get the car looked at and have it quoted.
How much is going to depend on how bad the car is, and what your expectation is.
If your expectation is like the car left the factory you’re probably looking at a couple days to do the entire underbody and you’re probably somewhere in the $1500 range. If the undercoat is very heavy and still well adhered there’s a possibility that dry ice blasting may not even remove it. Some systems can strip paint but most meant for cleaning operation are purposely not that powerful.
-Jason
1969 Pontiac Firebird
Old 03-31-2024, 09:17 PM
Held for Ransom's Avatar
Expect around $3000-up.
So long, farewell.
The Following 2 Users Say Thank You to Held for Ransom For This Useful Post:
Old 03-31-2024, 10:23 PM
I saw an invoice on BaT where Dennis Collins had a survivor (northern) 72 Z28 done.
Seems like it was between $3000-4000
It sold not very long ago if you want to search for it and see the invoice.
Green car
It was probably a max effort operation.
Old 03-31-2024, 11:15 PM
65madgoat's Avatar
Every shop around here in SoCal quotes undercarriage cryo cleaning work for around $2000 to $3000 --- and two days to do it. But being undercoated I would expect to pay another thousand at least!!
Engine cleaning is also an extra cost.
The Following User Says Thank You to 65madgoat For This Useful Post:
Old 03-31-2024, 11:54 PM
Green car
Looked it up.. $3,750 which included under the hood too..
I watch his coffee walk youtube channel. Saw the video where he purchased the Z/28. Looked like a nice original car. Wonder what he paid??
Old 04-09-2024, 02:17 PM
daduck's Avatar
daduck daduck is offline
Default ice blasting
friend of mine had his Cutlass blasted.
He said it was a total waste of money.
Would have been better off Power Washing the undercarriage at the Self Serve car wash.
Old 04-09-2024, 02:29 PM
1967gto1 1967gto1 is offline
My 80 z28 undercarriage was covered in rustproofing. I used mineral spirits and old cut up bath towels. I don't know how many hours it took, but it worked great. Took it right down to the paint. I wouldn't pay 3k-4k to have the underside blasted. Cost me 2-3 gallons of mineral spirits and my time.
The Following User Says Thank You to 1967gto1 For This Useful Post:
Old 04-09-2024, 02:34 PM
Bill S's Avatar
Bill S Bill S is offline
Experimented with dry ice blast cleaning decades ago in my manufacturing engineering days We found the air pressure had to real high for it work to any meaningful impact. Needed hearing protection, so no go. I agree, with trying pressure washing first.
I remember also trying nut shells and plastic beads. Nut shells = combustion risk from the dust cloud. Plastic worked okay.
Old 04-09-2024, 02:39 PM
65madgoat's Avatar
Cryo blasting at the right pressures preserves paint marks, decals and stickers, rubber, etc. The right person doing the cryo work is paramount.
Regular (high) pressure washing does not work nearly half as well in those regards.
Old 04-09-2024, 03:30 PM
Cammer-6 Cammer-6 is offline
one of my cars was ziebarted when new.
I stopped in a Rusty Jones shop and asked how to get the stuff off.
"We've never had anyone ask that before,we use mineral spirits for clean up"
I did just that and was amazed at condition of all the paint,plating etc.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 04-10-2024, 03:07 PM
mgarblik mgarblik is offline
I am probably going to have some dry ice blasting done on a 73 Firebird in the next 2 months. It was restored, body on, in the late 1970's. Everything from the firewall forward looks great and doesn't need any attention. From the firewall back, the car has factory/dealer undercoating and a little crust here and there. I have a privateer individual who bought out a dry ice blasting business and said he would look the car over in a month or so. If his price isn't crazy, probably going to have it done. I will report back and take some pics. I will have the engine/exhaust/transmission, and gas tank out. So access will be pretty easy.
Old 04-10-2024, 07:18 PM
Half-Inch Stud's Avatar
I used a putty knife to pry thick undercoat areas, and mineral Spirits for thin undercoat areas.
Old 04-11-2024, 12:50 PM
Bad things happen using a metal putty knife.(ask me how I know)
Its better to use plastic ,like bondo spreaders or application squeegees used for PSA vinyl applications.
The odd shaped white one is the sharpest and is called "Lil Chizler"
