Old 05-24-2021, 03:58 PM
SRR's Avatar
SRR SRR is offline
Default Holley carb. overhead view 1 minute vid.
https://www.youtube.com/watch?v=OKgYEZCqlbc
I never realized that fuel continues to be pulled from the accelerator pump nozzles?
― Calvin Coolidge
Old 05-24-2021, 04:21 PM
Sure does if you don't have your carb set up properly.
Old 05-24-2021, 07:10 PM
4 venturi rings look to provide ideal atomization ( does Holley make emulsion occur like a Q-JET?)
Accel pump Pri and Sec seemed mormal. But both drool at WOT?..hmmm.
Old 05-24-2021, 07:16 PM
That is the normal Down-leg booster design that Holley has used since the 1960s, HIS.
Have you checked the fuel level in the bowls, SSR?
Old 05-24-2021, 09:01 PM
misterp266's Avatar
According to Holley Tech, latter model carbs with rubber accelerator pump checks are prone to pullover due to vibration causing the rubber check to act as a small pump. If that’s the cause, switching to ball check bowls would fix it.
" Darksiders Rule "
Old 05-30-2021, 02:40 PM
SRR's Avatar
SRR SRR is offline
https://www.youtube.com/watch?v=Hy8rufA6Pyw
When one isn't enough.
― Calvin Coolidge
