Old 09-09-2024, 10:12 AM
Ragtop Man's Avatar
Ragtop Man Ragtop Man is offline
Default Starter Shim Question
So, I'm sending the old starter to the museum after the wiring meltdown.
Found two shims when I removed it.
Does the new starter use the old shims? Or is there a measurement that needs to be made and shims added/removed?
And what direction does the open 'c' eng point - to the block or away? Thanks!
Old 09-09-2024, 01:41 PM
Kenth's Avatar
Kenth Kenth is offline
Use enough shims that it will be possible to insert a 1/8" allen key between the starter ring and the starter pinion shaft without being able to turn the key.
The open end of the shim should be against the inner screw, the other end is extended to hold the shim during assembly.
HTH
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 09-09-2024, 02:55 PM
Ragtop Man's Avatar
Many thanks for the tip!
Starter arrives in a few days, have some wiring repair in the meantime.
Old 09-09-2024, 11:32 PM
The shims are slotted so you can start the inside bolt without worrying about holding the Shims in place too. You start the inside bolt and let the starter hang and slide the shim(s) in. Install the other bolt and tighten both.
Old 09-10-2024, 10:37 AM
Ragtop Man's Avatar
Many thanks, makes perfect sense.
Old 10-02-2024, 10:16 PM
SR-71 SR-71 is offline
Try this
Name:	starter shimming-1.jpg
ID:	640869   Click image for larger version
Name:	starter shimming-2.jpg
The Following 2 Users Say Thank You to SR-71 For This Useful Post:
Old 10-03-2024, 10:17 AM
Ragtop Man's Avatar
Very helpful! Many thanks!
Thread Tools
Display Modes
