aerosol carbs?
i've never seen one of these up close. i came upon the website by accident looking for a drop base air cleaner for a dominator. now i see somebody has one for sale on either this board or PZ board. does any body know how well they work? what are the advantages? thanks for the info.
C&S is known for their aerosol carbs. Holley basically had the same deal on their 1050 3 barrel secondaries.
C&S builds some nice blow through carb stuff as does the Carb Shop and CSU. An Aerosol design carb has a linear fuel curve which may or may not be the hot ticket for some applications. If you can buy the carb cheap then try it, (just like any carb purchase ). The carbs are NOT "Smoke and Mirrors" but are also not for every combo. They usually want "your left one" for a new carb too. Tom Vaught
Scott,
Here's C&S web site: http://www.candsspecialties.com/index.html What I think is neat is they use a smaller tube under the larger main tube for low speed use... Very cool and hi-tech looking but there is no real fuel atomization like a booster if you want to tool around on the street. These are really intended for max flow |
Looks like Q-jet rear nozzles.
jeff, thanks for the link. just wondering if anybody had any real world experience. i thought it looked like a cool idea, but since i drive mine on the street was questioning the "drivability" without the booster to create signal.
re c&s carbs
i have the 051500 series carb on my goat. it is the 1500 cfm model. the guy at c&s says it actually flows in the 1550 range. i have only ran it a couple of test hits, but the carb seems to work nicely.
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
what intake is that, it looks huge.
intake? what intake?
something he picked up from a junkyard on the bayou i think... |
it was a little known option in 66 for 15 bucs more.... over the standard 4bbl...
So... I went to the C & S site to look around...
On their home page I got a glimpse of something weird- looks like a pair of 2-bbls with a common aircleaner base, or a 4-bbl with a huge space between primary and secondary sections! What the heck is the thing??
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926} |
I have a C&S 1150 on my 482. When it was on the Vrbancic Brothers dyno (they also own the Carb Shop) they tried one of the Carb Shop "mule" carburetors. I believe it was a 950HP. It did just as well as the C&S. As to drivability, mine is just a racecar, but I have not perceived any drivability issues.
It turns out that the "weird" carb pictured on the C & S website is a "strectched" dominator that they built for a mud-race truck.
Awww yeah, the punisher intake made of CF !
That thing looks cool and it makes your 1500 CFM carb look like a teeny, tiny little thing
Knock Knock Knockin' on 11's Door '70 Judge, Palladium Silver w/Red Interior Powered by SD Performance, Ported 6X Heads 501 HP, 554 ft lbs TQ 12.14 ET @ 114 MPH , Supercase Muncie M22, 3:55 Suspension: HO Racing, BMR< Sykorat, and Bilsteins Narrowed 12 bolt , 16x8 VintageWheel Works, Comp T/As on street, MT Drag Radials @ Strip http://www.sdperformance.com/custome...1.php?carID=42 |
"I have a C&S 1150 on my 482. When it was on the Vrbancic Brothers dyno (they also own the Carb Shop) they tried one of the Carb Shop "mule" carburetors. I believe it was a 950HP. It did just as well as the C&S." Jim, that must have been one really good 950HP carb (750 cfm) to work as well as a 1150 cfm dominator. Tom Vaught
Tom - I might not remember which model it was. I thought he said it was a 950HP, but it sure looked like a standard Dominator.
in a nut shell that's all they really are...
462", 400 block w/displayed caps, mech flat tappet lunati, 11-1 compression, lightly ported #13 heads, e-85, vortech z-trim. 781rwhp@6300rpm on 15.5psi.....blow thru carbs sort of work. csucarbs.com |
