Old 01-03-2008, 08:32 PM
PLAY400's Avatar
PLAY400 PLAY400 is offline
If you go to the bolt on 1's it is the time to install new spring bushings and Cal Trac etc as you will have the springs out. Had a @#$% of a time reinstalling the front spring hanger. GRRRRRRR
Old 01-03-2008, 09:17 PM
gkinch's Avatar
gkinch gkinch is offline
I know I just purchased a slide- a-link traction bar to install with the new 9 inch rear .then I thought about subframe connectors. the car allready has new rear springs so hopefully everything will come right out!
thanks for all of the help
Gene
Old 01-04-2008, 01:37 AM
Y81all's Avatar
Y81all Y81all is offline
I'm going to go with www.pro-touringf-body.com subframe connectors... they can be bolted or welded... I'll go with welded. As a matter of fact, I'll probably get their whole "Stop Flex Kit" which included the SFCs plus solid body bushings and firewall g-braces. http://www.pro-touringf-body.com/cha...omponents.html
Jon O'Neall
1977 Y81 T/A
W72-400/Auto
"Trans Am! What's your pleasure?"
Old 01-04-2008, 08:25 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Not sure about the FB's, but I had to make access holes under the rear seat to install longer bolts and nuts/washers. The bolts pulled out of the factory threaded holes first time we went to the track! I would just go ahead and use longer bolts with nuts and washers for the front spring perches right from the start.
We bought the bolt in CE bars, and welded them in place, a LOT easier than removing the exhaust system and drilling holes!......Cliff
Old 01-04-2008, 08:58 AM
77birdman's Avatar
77birdman 77birdman is offline
I had a local race shop fabricate and weld my subframe connectors for around $450.00. I already had beefed up PST suspension and shocks, but with the connectors the handling just got 200% better.
Can do the talk, can't do the walk......therefore need deep pockets
Injection is nice but I rather be blown
If you got it flaunt it, if not fake it (Snoopy)
Original 1977 Firebird / Welded tube frame connectors
TH350 with shift kit / 400 bored/stroked to 455 by PDude
OCD=Waxing and polishing your oil filter
SICK=wetsanding your exhaust pipe
Old 01-04-2008, 01:32 PM
form74's Avatar
form74 form74 is offline
I used the Alston Racing ones and opted to bolt them in instead of welding, drilling the frame was tough, especially in the rear frame rails as their is double sides on these. Here's a few shots of them.
ID:	116971   Click image for larger version
ID:	116972   Click image for larger version
ID:	116973   Click image for larger version
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.075 @ 112.70
12.092 @ 112.43
12.128 @ 111.71
Old 01-04-2008, 02:40 PM
form406's Avatar
form406 form406 is offline
when i had a 462 under the hood and did a burnout in front of a friend his eyes bugged out of his head and he told me he saw my car "fold" upwards between the door and front fender...
'74 formula 400, w/shaker (3 scoops) black deluxe interior, '70 406 balanced assembly, .30 trw slugs, moly rings, 4x heads 2.11/1.77 stainless valves, ra 4 cam, e-rpm intake, holley 750 vac. sec, msd hei, hooker headers w/ dual 3'' flowmaster 50 series ending at axle, t400 w/ GM6 convertor, transgo shift kit, b&m starshifter, 3.08 gears, centerlines, 265/50-15 bfg's rear and 235/60-15 front...yes im over cammed but it is still very fun...
Old 01-05-2008, 01:33 AM
guccieng's Avatar
guccieng guccieng is offline
i have the global west connectors on my c-word (see sig). easy to install. weld in on the rear rails and bolt on the front with the ability to remove the frame when needed. with solid bushings, motor mounts and suspension bushings, the body has no creaking whatsoever. so quiet you could hear a mouse fart when i launch at the track (except for the exhaust)!
John J.
Old 01-05-2008, 11:14 AM
Eighttime's Avatar
Eighttime Eighttime is offline
I like this method the best out of it all. By only welding the rear in, you leave open the possibility of removing the front subframe without a plasma cutter. So, no creaking with the front bolted in?
"Trust me friend, a hundred years goes faster than you think." -Kenny Chesney
"Go fast, turn left, hang on, go straight, go faster...who wouldn't wanna piss off 900 angry horses?"
1967 Pontiac Firebird 400 Coupe
1966 Chevrolet Corvair Monza 110 Convertible
1965 Oldsmobile F85 Cutlass 350 HO Coupe, soon to have Olds 403
1970 Chevrolet Nova 383 Coupe, NEW!
2007 GMC Sierra 5.3 Z71 Ext.
2007 GMC Yukon 5.3 SLT
Old 01-27-2009, 01:26 PM
dean7276's Avatar
dean7276 dean7276 is offline
Originally Posted by wheelspin View Post
Weld BOTH ends of the connectors to the sub-frames; it's hard to describe the continous squeaking eminating from bolted on conectors .
Les
So true! I spent hours and hundreds of dollars rebuilding my front susp.as mostly all of us have, only to "bolt in" the sub-frame connectors.Now it sounds like a 30 year old P.O.S. squeaking down the street.My next dollar goes to solid bushings,then straight to the local welding shop!!
Brakes? Who needs brakes,they'll just slow you down!!
