Old 01-27-2009, 09:07 PM
opnwide's Avatar
opnwide opnwide is offline
Default wrong pistons for my 4.25 crank/6.8rods?
Just mocked up piston #1, and this is what I've got. The piston sticks .169" out of the hole! I am using an Eagle 4.25 crank and Eagle 6.8 BBC rods. I measured the rods and they're 6.8", if I'm doing my math right. I don't know how to measure the crank, but I have to assume its the correct one. I don't know how to confirm my pistons are correct, however. Its got to be the pistons, right? The block is a virgin '76 with 87K miles. The machine shop is waiting for my order as far as how much to deck.
I got the forged Ross flattops from Butler.
The spec sheet says 66997 on the top (job card #).
Dome height =0
pin diam=.980
bore 4.181
CH 1.495
CAM J
greg
1976 SE 455 twin turbo
austin, tx
Old 01-27-2009, 09:22 PM
J.C.you's Avatar
J.C.you J.C.you is offline
sounds like that piston is for a 6.625 rod, if you use that stroke crank. 6.8" - 6.625"= .175" Would put you .006" in the hole. About right.
If you wanted you could swap rods or pistons, if they had a 6.625 rod with a bbc crank pin.
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
Old 01-27-2009, 09:33 PM
Ken -Ace- Brewer's Avatar
Ken -Ace- Brewer Ken -Ace- Brewer is offline
Send a message via Yahoo to Ken -Ace- Brewer
It is absolutily the wrong piston. C/H should be around 1.295.
Ace
Am I glad I got out of the business I was in? HELL YEAH!!!
Old 01-27-2009, 10:00 PM
opnwide's Avatar
Thanks.
That what I thought, but Butler was already closed when I found the problem. I'll give them a call tomorrow to exchange them.
greg
austin, tx
Old 01-28-2009, 06:27 AM
PONTIAC DUDE's Avatar
Post FWIW:
What is the pin diameter of those 6.8 rods?
That is a 455 piston for a stock length 6.625 rod with a stock type Pontiac .980 pin.
Old 01-28-2009, 07:52 AM
GOSFAST GOSFAST is offline
Default Wrong Pistons
I'm just curious about 2 items?
First, what pin did you use for the "mock-up"?
And second, was this purchased as a "balanced" rotating ass'y or does it need to be balanced still!
If it's the former, already balanced, you may have other issues for sure!
Thanks, Gary in N.Y.
P.S. You may want to check the damper "press-fit" on the Eagle shaft beforehand also!! There are many undersize "snouts" in the marketplace on their "cast" pieces on the Chevy platform?
