Old 05-27-2021, 07:46 PM
rod cole rod cole is offline
Default camshaft too big?
Going from a hyd roller to solid roller. Camshaft i had was 260/263 on a 110 ls 570 lift. Solid I have is 272/272 ls 106 lift is 720 . Is this to much cam for 4500 stall converter 370 gears and weights 3600 pounds. current cam with 3700 stall goes 10.65 at 125mph. Bracket car wont rev past 6500 has unported high port heads 12 to 1 compression . Thanks Rod
Old 05-27-2021, 07:56 PM
AG's Avatar
AG AG is offline
What size is the motor?
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 05-27-2021, 08:21 PM
Dragncar Dragncar is offline
Single pattern, tight ls, 272 int dur is not exactly small for a 455 or stroker. 3.70 gears, 4500 stall, heavy. I would find a better cam. Match could be better.
If you are going to do it do it right.
Old 05-27-2021, 11:29 PM
It is a .030 over 455 with a super victor and dom carb
Old 05-27-2021, 11:30 PM
69Goat1's Avatar
69Goat1 69Goat1 is offline
My old cam in my 455 I had years ago that ran high 9’s in Judgment Day was a 272/276 on a 108 with a .440 lobe with my old Eheads. Car weighed same as yours and had same stall but ran 4.11 gear...
