Old 01-27-2003, 08:44 AM
67gtoforjer 67gtoforjer is offline
Should I remove the original a/c out of my 67 gto?
I am upgrading to a 455 w/6x motor and am wondering if it would just be easier to remove the compressor and not deal with it. Thanks.
Old 01-27-2003, 09:05 AM
Half-Inch Stud's Avatar
Leave it in.
If needed, Any garage can convert it to modern coolant for about $260.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
Old 01-27-2003, 09:57 AM
David Jones's Avatar
Does it work? If not how bad is it? If it does do you use it? Mine has been out for a year while I tinker with the motor. After that I will probably put it back in, but then I will have to deal with some wiring and fan issues inside. At this point its in the way and down on the list of priorities.
http://kurtspontiac.homestead.com/DavidJones69GTO.html
Old 01-30-2003, 05:52 PM
i'd leave it in. as stated above it's not bad to convert and a/c is nice sometimes. mike
former." --Albert Einstein
- Winston Churchill
Old 02-08-2003, 10:46 PM
Guest
Posts: n/a
I'll take it if you don't want it.
