Designed for Pontiac timing covers that came from the factory with a plastic timing tab? Fits all covers without a molded timing marker in the cover. Tab is made to fit the full size standard harmonic balancer.
One piece solid metal construction. Replace that missing, broken, or weak plastic timing tab with a solid steel one today! Fits Pontiac V-8 applications including 326, 350, 389, 400, 421, 428, and 455 engines.
Timing marks are not set on this stamped tab. If you need marks for OE spec please contact us and we will mark it for you or you may mark them yourself.
They are purposely designed without marks as many have degree the crankshaft and asked to set 0 themselves.
$15.95 plus shipping
http://www.ebay.com/itm/161615384875...84.m1555.l2649
