Tri-Power Tech 57-66 Tri-Power Talk
Old 03-18-2020, 03:41 PM
backn65's Avatar
backn65 backn65 is offline
Default tri-power work with HEI and power brakes booster.
i am looking into switching from a quadrijet for a 65 tripower setup , my 65 lemans has a HEI and power brakes. i saw a post that stated you might be able to grind some material off the manifold and make it work. what about the HEI?
do not want to do if there are a lot of mods to be done.
i have an opportunity to purchase the tripower and am thinking it over.
thanks,
paul
Old 03-18-2020, 04:04 PM
You will be grinding on the carb body, carb base and the intake.
https://forums.maxperformanceinc.com...41&postcount=5
If it were my car I’d plan on switching to a smaller diameter distributor.
Old 03-18-2020, 04:06 PM
Dick Boneske's Avatar
Yes, there is a guy who sells HEI distributors with a smaller cap and body. There are many low-cost, low-effort options to the large HEI body.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 03-19-2020, 01:10 AM
backn65's Avatar
thanks guys for the info.
