Old 04-17-2021, 12:09 AM
backn65's Avatar
backn65 backn65 is offline
Default 8 lugs wheels on an A body
Is it possible to install 8 lug wheels on a 65 A body? is anyone aware of that happening? if so, what had to be modified?
thanks
Old 04-17-2021, 01:12 AM
Chris65LeMans's Avatar
That’s something I’ve thought about, too. I’d think that if the narrow space in the rear wheel Wells isn’t an issue, it can be done.
Old 04-17-2021, 06:10 AM
Jeff Hamlin's Avatar
It can be done, but I can't help with any details on what it entails.
PMD had plans to offer them on the A-Body platform but it was said to be too costly.
Old 04-17-2021, 01:05 PM
Big Bear's Avatar
Big Bear Big Bear is offline
This was in the parking lot at Norwalk.
ID:	564913   Click image for larger version
Old 04-18-2021, 12:23 AM
backn65's Avatar
thanks for the responses, they look good, would like them better with blackwalls, or red lines.
Old 04-19-2021, 06:18 AM
I would look into getting the factory specs of the early B-Bodies rear axle and front spindles to determine what it may entail.
Knowing the rear drum bolt, pattern/backspace along with spindle dimensions would at least give you a starting point.
ID:	564979   Click image for larger version
ID:	564980   Click image for larger version
ID:	564981   Click image for larger version
Old 04-19-2021, 09:56 AM
Keith Seymore's Avatar
Maybe it's the wide whites, or the black paint between the fins, but ….
I don't love it.
And that's coming from someone who's been an 8 lug fan for a very long time.
K
ID:	564988   Click image for larger version
Name:	Grand Prix Keith.JPG
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
Old 04-19-2021, 04:31 PM
Stuart's Avatar
Stuart Stuart is offline
Scarebird has been working on a long term project that would recreate the look of a factory 8 lug wheel by using a flat plate that would bolt to the hub, with a 3D printed decorative cap on top to mimic the 8 lug hub. If it ever comes to fruition, I'd think the design could be adapted to match the bolt pattern of an A body. https://forums.maxperformanceinc.com...d.php?t=846445
I don't love it.
K
Personally I prefer the look of the early 8 lugs that didn't have the black paint between the fins, along with the skinny trim rings instead of the later ones that covered the entire rim. On the '61 Bonneville convertible I used to own, I ran the 8 lug wheels with no trim rings at all and I thought that looked pretty good, too.
Old 04-19-2021, 07:35 PM
Thumbs up
I don't love it.
K
I just looked at the wide whites as a nod to early years
Old 04-19-2021, 07:37 PM
Not as wide but cool nonetheless...
