Old 02-08-2023, 12:45 PM
Kenth's Avatar
Kenth Kenth is offline
This:
Name:	Colour Letter.jpg
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
  #62
Old 02-08-2023, 03:16 PM
Built 2 weeks after the bulletin date should Definitely make it amongst the first cars built that color.
Your Bsheet shows it was a Customer Order
So they must have came along within days after the dealer received that bulletin.
Or perhaps there was a leak about the color becoming available soon , and they were just holding the order until it was fully official.
It is a neat factoid to tie the car in with it that way.
Going to be hard to find another one any earlier .
  #63
Old 02-08-2023, 09:34 PM
gtome's Avatar
gtome gtome is offline
I got the car In Muscatine, Iowa. It was definitely there since 1983. Obviously someone bought it in Illinois though. When I talked to the previous owner, he said the guy that he got it from bought it used.
  #64
Old 02-08-2023, 09:36 PM
gtome's Avatar
That's fun to think that I may have the very first OO Judge! Too bad there is no way to verify that.
  #65
Old 02-24-2023, 09:45 AM
gtome's Avatar
I have the parts to do my outer wheel houses and quarters. I'd like to put new body bushings in it before I do any work. Is there any that are better than the others?
Oh and other good news is what was left of the original engine is in route to me right now!
The Following User Says Thank You to gtome For This Useful Post:
  #66
Old 02-24-2023, 10:16 AM
OG68 OG68 is offline
Inline Tube has some accurate reproductions down to different colors and molded part numbers. But be sure to research which colors were used at each position.
IT would like you to think 68-72 are all the same as well as each plant.
AMK and our sponsor have the best mounting bolts with the pointed tip.
The Frame chapter at the beginning of the service manual lists by part number, which bushings go where and the corresponding bolt size.
And don't use an impact to remove the bolts. A half inch drive, 16' ratchet with a slow and easy approach works best for rusty bolts.
2007 Cadillac SRX
Old 02-24-2023, 11:22 AM
gtome's Avatar
Thanks. Maybe I will hit them with some PB blaster now.
  #68
Old 02-26-2023, 09:45 PM
4dblnkldude's Avatar
I just read your whole thread. Its great that you somehow managed to hold onto it all these years! I wish you the best with it.
  #69
Old 02-26-2023, 10:42 PM
gtome's Avatar
Thanks. My buddy is picking up my engine for me tomorrow!
  #70
Old 03-06-2023, 03:34 PM
gtome's Avatar
Anyone have a nifty trick for getting these rusty nuts off without the stud spinning? I tried a little handheld torch to heat it up but it still spun.
  #71
Old 03-06-2023, 04:42 PM
Jason67's Avatar
Jason67 Jason67 is offline
Cut a small slot in the end of the bolt to hold with a flat blade screwdriver, hold the molded carriage bolt and use a combo wrench to remove the nut. Kroil and a little heat helps too.
Jason
  #72
Old 03-06-2023, 10:09 PM
gtome's Avatar
Oh dang that's a good idea! I already took a die grinder to the nuts. Once I had a bit removed they came right off. Now I have to get new nuts though.
  #73
Old 06-25-2023, 07:41 AM
gtome's Avatar
I have the quarters and outer wheelhouses done. I hope to start stripping the rest of the car soon. It's been mid 90's degree temps here and monsoon rain, so I haven't been doing much with it lately. I was organizing some parts yesterday, and happened to notice some remnants of the judge stripes left on the front fenders. The car had been repainted when I got it and there were no stripes. I thought that was kind of fun.
  #74
Old 07-26-2023, 03:18 PM
gtome's Avatar
I am getting ready to strip the paint off of my spoiler. I don't know if you can see it in the pic or not, but around the spoiler stand, you can see an indentation of where it was moulded into the spoiler. Do you guys leave it like that or make it nice/flush?
  #75
Old 07-28-2023, 05:32 PM
Nocar's Avatar
Nocar Nocar is offline
Apologies if I missed it, but did your friend pick up the engine? What a score! Check the partial VIN on the front and see if it is original to the car.
1966 GTO
Isaiah 6:8
  #76
Old 07-28-2023, 11:17 PM
gtome's Avatar
Yeah he got it. It's in pretty rough shape and will need some sleeves, but at least I was able to get it.
  #77
Old 08-04-2023, 06:23 PM
MatthewKlein MatthewKlein is offline
Originally Posted by gtome View Post
Success! The previous owner found the block, crank (which is cracked), heads, exhaust manifolds, and rods and pistons. He wasn't able to find the cam/lifters, intake, carb, or distributor. I'm beyond happy! Even agreed to give them to me, I just have to make the 1200 mile drive.
Talk about hitting the jackpot! Good for you
  #78
Old 08-04-2023, 06:34 PM
These work very for heating without worry of damaging surrounding objects like heating with a torch can do
https://www.summitracing.com/parts/i...RoCvbwQAvD_BwE
  #79
Old 08-14-2023, 06:56 PM
Just stumbled across this OrbitO that is 11A trim tag. wOw
It even pre-dates the sales bulletin !
Just got listed on Bring A Trailer today .
Going to be hard to find an earlier one than this one .
https://bringatrailer.com/listing/19...am-air-iii-13/
  #80
Old 08-14-2023, 07:25 PM
Held for Ransom's Avatar
Yup. Been watching since it came up. What's your take on the 13-244? And the later ship?
So long, farewell.
