Old 09-27-2020, 01:56 PM
67drake's Avatar
67drake 67drake is online now
Default Carpenters- how would you do this?
Putting in 1/2” thick oak baseboard trim. How do I make this look good? There’s a small “step” in the wall, but too thin to do anything with.
Ps. I’m no carpenter!
13.95 @ 102.1 on street tires @ 4055lbs.
Old 09-27-2020, 02:00 PM
65gto69's Avatar
65gto69 65gto69 is offline
notch the bottom of the base board at the step keeping the top at one elevation
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, TCI Flex plate, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi.
Old 09-27-2020, 03:06 PM
67drake's Avatar
Thanks for the reply. I don’t understand though. The vent is on the floor, first pic might be confusing.
The step in the wall is about the thickness of the trim itself. Just wanted it to look clean without the end of one showing, figured the pros must have a trick
Old 09-27-2020, 04:45 PM
67drake's Avatar
Screw it, it’s a rental!
Old 09-27-2020, 06:12 PM
Stuart's Avatar
Stuart Stuart is offline
I'd miter the end of the board that is further out, then cut a small return piece to go to the other board.
Old 09-27-2020, 06:31 PM
65gto69's Avatar
I agree with this answer, which is what I would have said, but I saw the first pic differently.
Your last pic looks really good though, I think you solved your puzzle.
Mark
Old 09-27-2020, 08:02 PM
scott70's Avatar
scott70 scott70 is offline
creative bondo
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 09-27-2020, 08:44 PM
67drake's Avatar
That’s what I figured, but it would go from about 1/2” to nothing with the taper of the ranch trim.
Thanks for the help though. You don’t even notice it unless you’re sitting on the throne in there.
Old 09-27-2020, 08:53 PM
indymanjoe's Avatar
indymanjoe indymanjoe is online now
Caulk and paint make you the carpenter you aint. Truth! its a rental..
Old 09-27-2020, 10:14 PM
tooski tooski is offline
Rental, but you did not say if you are the tenant or landlord. A landlord would not be concerned as he/she does not live there. A tenant is minimally concerned as he/she does not own the property (unless the tenant is very long term or permanent). I have been both. A somewhat extreme fix would be to install another piece of drywall over the inset piece. Then finishing is involved. then the complete wall would look much better.
Also, you could just get a 1/2" thick piece of solid lumber the same width as the base board to bump out the baseboard from the inset drywall.
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
