Old 04-07-2004, 06:16 PM
norton70 norton70 is offline
WHEN A 70 DOOR SAGS, WHAT IS THE EASIEST CURE, OR THIS THERE AN EASY CURE...PINS, HINGES, WHAT SHOULD ONE LOOK AT FIRST, OBVISIOUSLY I RATHER NOT REPLACE HINGES IF I DONT HAVE TO, CAN PINS HELP? ANY HELP WOULD BE APPRECIATED
Old 04-08-2004, 07:21 AM
quicksilver97ta's Avatar
Pins will fix it. Be sure to replace all of them including the one with the little roller. You have to remove the door and then the hinges to work on them but it will be like brand new.
Old 04-08-2004, 08:55 AM
dennisk dennisk is offline
If you need hinges I have a BUNCH of them. $40 pair plus shipping. Pair does 1 door.
