Old 01-16-2017, 12:26 PM
frbformula's Avatar
frbformula frbformula is offline
Default Harmonic damper
What harmonic damper is everyone using? Please post part number if available.
Old 01-16-2017, 01:52 PM
steve25 steve25 is offline
For full on race, or under 6000 rpm street strip?
Old 01-16-2017, 01:59 PM
frbformula's Avatar
80% street 20% track. I shift it at 6600rpm when I beat on it.
Old 01-16-2017, 02:37 PM
ATI Super Damper - 917160
Best there is.
Old 01-16-2017, 03:55 PM
janderson's Avatar
janderson janderson is offline
ATI x 2
Old 01-16-2017, 04:11 PM
Old Man Taylor's Avatar
I also use an ATI.
Old 01-16-2017, 04:13 PM
wreckmastr's Avatar
ATI here also
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
Old 01-16-2017, 05:07 PM
Hooter's Avatar
Hooter Hooter is offline
ATI on both my cars as well.
67 Bonneville ragtop
Old 01-16-2017, 05:19 PM
Tom Vaught's Avatar
Boost Engineer
THREE ATI Super Dampers on my stuff. One is a custom 10 rib Supercharger Hub deal built into the damper ring. (3 engines).
Tom V.
Old 01-16-2017, 08:35 PM
S/st 54's Avatar
S/st 54 S/st 54 is offline
ATI is all I run no matter the purpose of the motor...They are just real dang good balancers and really easy company to work with.If you have any questions call them great bunch of people.
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 10.890@157.08 MPH in Iowa in June’23 ,157.56 MPH in Gainesville in March ‘23
Old 01-16-2017, 10:34 PM
mgarblik mgarblik is offline
X2 They are the best.
Best there is.
Old 01-16-2017, 11:23 PM
Probird's Avatar
Probird Probird is offline
ATI here too!
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
Old 01-17-2017, 12:44 AM
PontiacMatt72's Avatar
PontiacMatt72 PontiacMatt72 is online now
I know nothing about a damper, so can someone explain the difference between the ATI and any other damper? What makes it so much better?
Matt
70 GTO 400 4-speed
"Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge
Old 01-17-2017, 01:55 PM
Ken MacNicol's Avatar
Ken MacNicol Ken MacNicol is offline
ATI here
Old 01-17-2017, 02:17 PM
chiphead's Avatar
chiphead chiphead is offline
Don't you have to re-drill the pulleys to use the ATI damper?
What would be one step down from the ATI, for a street/strip motor? Romac?
Old 01-17-2017, 02:26 PM
frbformula's Avatar
It looks like the ati is a 3 bolt and our pontiacs are 4 bolt. The big question is does the ati still have a hub that the pulley registers on? If so the holes dont have to be perfect and can be done with a hand drill.
Old 01-17-2017, 02:28 PM
Yes it has a hub that a stock pulley will center on.
Old 01-17-2017, 02:32 PM
The stock pulley would need re-drilled.
Could use a chevy type, but not sure about alignment.
Any kind of racing usually requires a SFI damper.
Don't know about that one.
Old 01-17-2017, 02:37 PM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
I used the powerbond/dayco sfi balancer and use stock pulleys without any redrilling . # 1056 ss, shift at 6200 . no issues
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 01-17-2017, 03:49 PM
455-4+1's Avatar
455-4+1 455-4+1 is offline
I bought the Romac a few years ago (steel hub, aluminium outer) would not fit with a Moon or stock timing cover. Emailed them with CAD drawings and photos showing the areas of interference. They told me they were CNC machined so couldn't we wrong LOL.
Showed them all the info again and reply was "what do you expect me to do about it ?".
NEVER AGAIN !.
Name:	romax on stock cover.JPG
ID:	445146   Click image for larger version
Name:	romac hits sump etc.JPG
Working on going faster (and now staying dry at the same time !!)
