Old 04-17-2020, 09:26 PM
SD455DJ SD455DJ is offline
Dan restored and installed the correct air cleaner and lid, so now is looking much more correct. Scott (Tiemann) added to correct stripes and inscriptions to the upper radiator hose. We also did a check of all the wiring and switches to make sure everything was working on hot where needed...and everything worked as they should...all the lights, switches, fan, horns, instrument panel, gauges, radio, etc. All the grounds were good and there are a lot of them on that big car.
Dennis
ID:	537684   Click image for larger version
ID:	537685   Click image for larger version
ID:	537686   Click image for larger version
ID:	537687   Click image for larger version
  #282
Old 04-17-2020, 11:56 PM
hawkins69 hawkins69 is offline
Do you know where Dan found the air cleaner decal?? Or did he have it made?? Looks to be the same as my 69 Grand Prix
  #283
Old 04-17-2020, 11:57 PM
Wow. Just gorgeous!
  #284
Old 04-18-2020, 10:01 AM
Hawkins69, Dan just ordered it from Ames. Fortunately, both the air cleaner and tune-up instructions are pretty faithful reproductions and match what's left of the original stickers very closely.
Dennis
ID:	537716   Click image for larger version
  #285
Old 04-18-2020, 10:29 AM
Good to know. That was my plan anyway, but good to know. Thanks
  #286
Old 04-18-2020, 06:30 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
It's almost ready to drive if you've got the electrical hooked up! Can't wait to see it finished.
  #287
Old 04-18-2020, 07:08 PM
77 TRASHCAN's Avatar
Is that 428 emblem in the engine compartment stock??? I like it!!!
Shut it off
Shut it off
  #288
Old 04-18-2020, 09:14 PM
muscle_collector's Avatar
yes they came that way.
  #289
Old 05-04-2020, 07:41 PM
Default Need Factory Exhaust Brackets/Supports
We are in need of factory exhaust brackets/supports for the Catalina...in particular:
Group 3.704 - 9777300 Bracket, Muffler - Rear (Qty 2)
Group 3.704 - 9783813 Support, Muffler - Rear (Qty 2)
Group 3.706 - 9783801 Support, Resonator (Qty 2)
These are circled in yellow on the illustration. Searching for hens teeth we realize.
Dennis
Name:	68 B-Body Exhaust Hangers.jpg
  #290
Old 05-04-2020, 08:10 PM
I’ve struggled to find these over the years. Waldron sometimes carries good period replacements that look very close to OEM. But they didn’t have any last time.
I fabricated them on my last project. Started with components from auto parts supply and had some hand cutting and forming done.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
  #291
Old 05-05-2020, 08:43 AM
North - We'll check a few other sources (RARE for one), but I believe we'll be taking the same route you had to and fabricate them ourselves.
Dennis
  #292
Old 05-10-2020, 03:50 PM
incommunicado incommunicado is offline
Default 67 428 muffler brackets
Dennis
I believe there is a set of 3813 brackets in the for sale section here.
  #293
Old 05-10-2020, 03:52 PM
421 HO 428 HO NOS 65-70
Aluminum Chief
This is the listing under parts for sale.
  #294
Old 05-10-2020, 06:26 PM
Aluminum Chief
Incommunicado - Got them...Thanks!
Dennis
  #295
Old 05-15-2020, 06:44 PM
Got the NOS 9783801 & 9783813 Muffler & Resonator Supports, now just need to get (or make) the 9777300 Muffler Brackets.
Dennis
Name:	68 Muffler & Resonator Supports.jpg
  #296
Old 05-18-2020, 10:55 AM
Default brackets
Franks Pontiac in CA might have the brackets you need? you can look online and see if they are what you need.
If not I might have a used set, but it will be 5 weeks or so before I am at home where the parts are stored.
  #297
Old 05-18-2020, 02:12 PM
Incommunicado - Thanks for the suggesting Franks, Ill check them out. The exhaust is 6 weeks out, so the timing may be right for you to check your parts stash...thanks!
Dennis
  #298
Old 05-18-2020, 02:27 PM
This is what Franks has
  #299
Old 05-18-2020, 02:33 PM
Incommunicado - We just got those NOS form Aluminum Chief...the 9783801.
Thanks for checking! We still need to the 9777300 Muffler Brackets that are at the rear of the muffler.
Dennis
  #300
Old 05-18-2020, 05:50 PM
Stuart's Avatar
Stuart Stuart is offline
Another possible source is CPR: http://www.pontiacparts.net/fullsizeparts.htm They don't necessarily have everything listed on their website, so if you don't see something there it's worth giving them a call. I imagine Frank's may be the same - if you don't see it on their website give them a call.
